Negatives about the Alberg 37? That depends a lot on your intended use. The boat is a pretty typical CCA-inspired design with all that means. The boat is heavy, slow in light air, quick to heel to 15 degrees or so, and will have weather helm issues that require some skillful sail handling to minimize. The low freeboard means that the boat is a relatively wet ride. I sailed on one once many years ago in about 20 knots of wind. It was not a comfortable ride. The weather helm was crazy strong, and the rail was close to buried the whole time. It was wet and wild. A lot of fun, but not something I'd want to do for more than a few hours. I never once felt that the boat couldn't handle the conditions, but this is not a boat I'd want to do any long distance cruising on. YMMV, but I was tired after those two or three hours; I don't see doing that for any longer, let alone days. And it takes a lot of practice and skill to be able to back one of these beasts up; those evolutions are almost always a adventure. You just never know which way it will turn. Hopefully not into your neighbor's boat. These are issues that are due to the design of the boat that you can't really change.
That all being said, the interior is nice and "woody". Cozy. Comfortable. I have no idea what the tankage numbers are on the boat, but the hull shape is not conducive to large water or fuel tanks, so I'd bet that they aren't adequate for long range, off the grid cruising. They are likely just fine for coastal hops of a few days though. I could see the boat as a comfortable, fair weather coastal cruiser.
Also, I think they stopped making the boat in the mid 80's, so any boat you see will likely be a bit long in the tooth, so all of the standard age-related issues are potentially in play that you should be on the look out for: spongy decks, cranky electrical systems, aging heads, poorly insulated iceboxes or freezers, etc.
Your budget of 50K to buy and outfit an Alberg 37 is more than reasonable. You should be able to get a well-equipped one for about 20K. You won't need to put 30K into it.
One thing all of the Albergs have: an off-the-charts row away factor. Old Carl knew how to draw a pretty boat.
Best of luck.
Best of luck.
