1 - 11 of 11 Posts
The question does not seem to be worth a lot of thought, IMHO. If you are concerned about the holding power of a particular fastener use a backing plate and through bolt the assembly.
I would always choose a tapped hole in steel over a self threaded hole.
Paul
Fiberglass is too brittle to take screws well. If the screws get highly loaded, the threads of the screw will just tear through the fiberglass.
Glass fibre never holds a fastener tightly for long and will wear away with even minute movement and a fine thread will leave very little "meat" for it to be strong in GRP (OK in metal). So a fine thread on a bolt will let go first, a course thread on a bolt will let go next, a course self drilling screw will let go third and a through-bolt won't let go at all.
I know what my choice would be.;)
BTW, if it's a light-usage fitting in reasonably thin GRP, the better fastener IMO would be a pop rivet of suitable size, as long as the end of the rivet goes all the way out the other side of the skin.
But still, a doubler plate on the other side would be my choice.
Discussion Starter · #9 ·
Yes - of course a backing plate and through bolted is the way to go, but not possible in all applications. I'm leaning toward the pilot drilled SS sheet metal screw......thanks for the help.
P.S. Sailingdog - couldn't stay away could you :)
Something I use--
After setting the screw remove it and put a drop of super glue in the hole and allow 24 hrs. before reinserting.
Wish I never found SN!
If you drill out the glass pot with resin then drill and tap with a course thread it will hold beter than just glass. But you will need plenty of meat around the screw.
1 - 11 of 11 Posts
