1 - 15 of 15 Posts
I would help if you told us what model Mac and what type of bolt (size, material, e.g. Magnetic or non-magnetic). You may be looking at having to remove the daggerboard to get the bolt out. You might be able to snake down a very thin wire, and/or tool like that used to unlock autodoors and fish it out.
Lots of luck.
Ed Warren
Discussion Starter · #3 ·
Thanks. Its a 1988 MacGregor 26D. Not sure what is down there but may be a bolt. I would guess it is metal. We tried to put a magnet down but we had already tried to get the board to go up and down and the piece is lodged tightly.
My boat is a 26s so, I can't be of much practical help. Here are some ideas, use each at your own risk.
1. Boat on trailer: go buy a length of thin aircraft cable from your local hardware (e.g. 1/8"), that largest that will slide down the side of your cb trunk. Drop one end down the forward outboard side, the other down the aft outboard side. Now you should have two ends hanging out the bottom of the slot on the bottom of the boat. Now drop down the center of the cable and you should have the offending bolt captured. Pull like heck to unlodge. Note: If you believe the offending bolt to be at the top figure out how to reverse the process and feed the cable up rather than down.
2. If the boat is still in the water ---??
Lots of luck.
If still in the water. Add length to your stopper rope and drop the board out the bottom. Then Keel Haul the offending DB and rope back to the stern and retrieve. Then you will have the fun of having to unstep the mast to get the DB back in.
Salty Dog
Like that plan, but can't you just get in the water with mask and snorkel and slip 'er back in from underwater???
Leave the piece of line going through for a helper inside the boat to pull on and help!!
I am sure that would work as well.... If you have a mask and snorkel.
Visibility here (Lake Michigan) is about 2' (if lucky, in the harbor) and that is with 20/20 vision. I'd sooner just close my eyes and go for the feel.
Can you rock the boat over on it's side and dislodge the obstruction, try tying the halyard to either an anchor, or the pier and lay it over as far as you can, then jiggle the board to get it moving.
Discussion Starter · #9 ·
Stuck Daggerboard
At this time the daggerboard is stuck in the up position. When the boat was still in the water we tried to push it down but it wouldn't go. We had to pull it up (with difficulty) to get the boat on the trailer so we could take it out of the water. We haven't had time to do any more as we've been working.
Thanks for all the suggestions. Hope we can get to try some of them this week-end.
my guess
first of all you know what free advice is worth ? so take it from there, I have a 26S so have no experience on your model. However I think the dagger board will have some taper to it so it would be best to take it out from the top as it is all the way up and is on the trailer. You may need to use a small jack on the ground to apply pressure and or a "come-along" from above. If you can supply any form of lubrication that might help, a good choice would be dish soap, can't do any harm and easy to clean up.
good luck, Bob
Discussion Starter · #11 ·
Stuck Daggerboard
Success!!! Went to Ace Hardware and purchased a piece of flat steel about 7 feet long and 3/4 inches wide. We could see the the stuck piece toward the front of the daggerboard. Don laid under the boat and directed as I placed the steel down the side of the daggerboard on the offending piece and kept hammering until it finally dropped out the bottom. Took about 1/2 hour and cost $8 so we're in the business of sailing again. :)
Read Only
Hope you did not hurt the center board. I would have put pressure and leverage on the board and pushed it up and out. Never hammer. Where on lake MI are you. I lived in Berrien Springs in MI 12 miles form the lake. Glad to be in California.
Discussion Starter · #13 ·
More 'splaining about the stuck centerboard
RStocker - - -
I'm not from Michigan... that was one of the members trying to give me some help. I'm in Southern California. Where in California are you?
I didn't explain the hammering process quite right.
I didn't hammer on the center board, I hammered on the piece of metal that we had slid down between the side of the opening and the board. I placed the metal on the offending bolt. I "hammered" with a rubber mallet for a while and then used the side of a crescent wrench. (Didn't have a hammer on board.) The piece of metal from Ace hardware kept slipping off but eventually (took almost an hour) the bolt fell out the bottom.:D
Ahhh, you used that trusy "sailor's friend" the Cresent Hammer ;)
I've heard, that they can also be used to turn nuts, but that may only be a myth. :rolleyes:
In any case glad to hear it came out for you, now get ready to enjoy another season of sailing, if this winter will every go away!!
Ed Warren.
Discussion Starter · #15 ·
We haven't sailed Fair Dinkum III this winter due to the little centerboard problem but we are flying to the British Virgin Islands this Friday for a bare boat vacation for a week.
Can't wait to get there. We've chartered a 51.5 monohull sailboat. There will be 7 of us. We did a similar trip last year at this time and loved it.
I do hope the weather is good when we get back so we can start sailing around Southern California.:)
1 - 15 of 15 Posts
