41 - 58 of 58 Posts
· Tartan 27' owner
Persistence pays off Jim. Good work!
Someone at your club will want that Buck Algonquin hose and hose clamps. Just maybe not this year. But you will make a friend if you "donate" those items, when the time comes.
· One of None
Hunter 34
Jimisun... clamp on... clamp off.... :) sand de floor... wax on wax off
Reactions: jimgo
Hi Jim,
Looks good! I tore mine apart today and the shaft pressed off OK! My stuffing box is only 1 3/4". Yours was 2", I guess the Allmands weren't standard. I'll post my pictures in a new thread this next week. I'm taking pictures as I go along.
Dave
· Master Mariner
Nicely done. Nobody at a boat yard could have done it better!
Now you have a new trade, should your job get sent overseas.
· One of None
Hunter 34
Tada!
I will say, I am REALLY glad that I had the shaft and flange fit and faced. The shop made sure the flange slid on fairly easily, which made assembly easy.
Looks great Jim!
Took this past week off to do our short haul. New bottom paint and replace the stuffing box, coupler and cutlass bearing. All was going well til the cutlass bearing. While pressing the old bearing out the strut started to fall apart. Crap! Galvanic corrosion. All because the PO got lazy and didn't replace zincs.
Spent the last 2 days getting access to the area where the strut is bolted on. Remove a holding tank. Remove the fuel tank and yes it was full. Ground out 2 of the bolts today. Should be able to get the other 2 tomorrow and then grind out the strut. What a PIA but I'm glad I discovered the problem before the strut failed.
· Asleep at the wheel
Discussion Starter · #56 ·
We splashed Thursday, and took the boat today. Had a little trouble starting her (batteries were lower than I expected), but eventually she started. Everything ran great! The packing gland dripped like it was supposed to. Maybe a bit too much, but not incredibly so, and I'll deal with that. I reached in over the engine at one point and although the engine was still hot, the stuffing box wasn't. So, I take that as a good sign.
Thanks everyone for your help and encouragement!
41 - 58 of 58 Posts
