1 - 5 of 5 Posts
I'm shopping for a replacement thru-hull and seacock, but I'm confused about how they are labeled. The hole is about 1/2 inch diameter, its 3/4 inch if I measure the width including the threads. Do I buy a 1/2 inch or 3/4 thru-hull?
(I remember reading somewhere that you measure the hole, but the site says "thread size", so I'd think you measure the whole thing, hence my confusion)
Usually their label refers to the hose/pipe conection size. A 1/2 inch thru-hull will need a little more than that when cutting the hole on hull. There are some bulky ones that require a bit larger hole. You probably have a 1/2 inch one, but best way is to measure it.
old guy :)
I have made the same mistake. My suggestion:
If possible (not always possible) take the old one out and take it to you favorite chandelier. Then you can compare side by side.
A good and worth while project.
Cheers
Rik
Sea Slacker
thru hulls and other fittings are measured according to "nominal pipe size". this is more or less an inside diameter of the fitting. I.e. the hole in your thru-hull will be about 1/2" in diameter if it is labeled as a '1/2" thruhull'. Outside diameter of all fixtures will vary of course (what's an outside diameter of a seacock anyway? :) ). For thruhulls outside diameter is about 1/4-1/2" more depending on size.
1 - 5 of 5 Posts
