1 - 4 of 4 Posts
Old soul
I've got an older Tacktick Micronet system that has worked really well, up till now. The wind direction indicator is now stuck in one direction. It is showing a direction, but it never changes. The masthead pointer is spinning, so it's not a mechanical problem. The wind speed portion (the cups) is still working, although it does get stuck -- mechanical problem no doubt.
Any ideas?
- Faulty transmitter at masthead? The windspeed system is working fine. I suppose they are different sensors up there. Maybe direction is screwed somehow.
- Faulty cockpit display? Again, windspeed is working, and it is displaying a direction, just the wrong one (never changes).
- Hull transmitter problem?
I'd check with RayMarine. Sounds like the transmitter is bad. I had the opposite situation - direction worked fine, speed was erratic. Luckily it was under warranty or it would have been a $200 bill.
Old soul
Discussion Starter · #4 ·
Thanks guys. I'm going to go up the mast to check it out. I'm hoping some sort of dirt/gunk/bird-poop issue is the problem. It have some hope since it appears data is being transmitted from the directional sensor, otherwise I assume it would show nothing at all.
Interestingly yesterday when I was at the boat we had pretty light airs (<10kn). I flipped on the tacktick display and got speed, but the direction was stuck at one location as usual these days: around 175. However, as I watched the direction indicator rotated around 180 degrees and stayed there (around 5) for a few minutes before jumping back to 175. It did this a few times.
Does this suggest anything to anyone?
1 - 4 of 4 Posts
