1 - 7 of 7 Posts
I recently purchased and am living aboard a 1989 Hunter 30. Since moving aboard I have been diagnosing smells, making headway with bilge and head odors but this one has me stumped! The wood in the v-birth smells like old sawdust/mud-dobber!
The v-birth has a built in hanging locker starboard and vertical storage cupboards port, I believe these are marine plywood laminated with teak and that they are the source of the smell. When I first moved on there were a few mud-dobber nests and I thought that was the source so I knocked them all out and cleaned all around in there, still smelled. A couple of days ago I disassembled everything in there and pulled it out, scrubbed every board individuality with bleach and water as well as the vinyl hull liner and wood that is glassed in to the hull (main bulkhead into birth and the two pieces that encase the water tanks that you sleep on top of). The wood still smells! I know it's the wood because yesterday when I got home I could smell the pile of 'clean' wood that I left on the dock to dry.
My next steep is to give it all a bath in vinegar (I know I should have done that first), then would be to Te-Ka clean it all and varnish it hoping to seal the smell in, although I would prefer to keep it natural and just oil it every year.
What could this be, has anyone experienced this, and what are your suggestions to fix it???
Thanks!
You might try cleaning the teak with TSP. Another option is to mask the smell... go buy a bunch of coconut air freshners and hang them in there for a few days.
I found this info googling, it pertains to Cigarette smoke smell but it should work with any smell. It mentions baking soda--which would probably be a good one to try as well.
How to Get Cigarette Smoke Smell Out of Wood | eHow.com
Thanks!
Do a new coat of varnish - that'll handle it. Teak doesn't actually smell unless freshly sawn. Seems the curtains, cushions etc are on you r bit perhaps... but then - make the boat glossy and varnish and wallah - the smell is fresh again..
Buy or rent an Ozone generator...a powerful one like hotel people use to de-odor rooms. Let the generator run a few hours with all your cabinets, drawers etc, open...give your cushions a good fluff and be sure they have maximum exposure. Don't hang around breathing the ozone...it can kill your bad breath too...permanently....but it works like crazy.
Howard Keiper
Berkeley
Discussion Starter · #6 ·
Solution
Ok, It wasn't the teak.. it was the ceder lining! Can't believe I missed the obvious, it just didn't smell like ceder.
Anyways, what finally wound up working to my satisfaction was just a dilute of orange oil sprayed and wiped all throughout. That tamed it down a bunch.
Thanks for all the suggestions. (Ozone was next)
CAUTION using Ozone Generators. Please read this EPA page on ozone. Low concentrations of ozone can make the air smell fresh. So can opening windows. High concentrations can kill mold and bacteria, but can also degrade plastic and rubber as well as being harmful to other living things.
I thought I'd share this since I'm trying to remediate some mildew issues on my boat and have been doing quite a bit of internet research.
1 - 7 of 7 Posts
