  • The winner of the February SailNet Captain of the Month is Howard @HPeer. A new competition starts April FOOLSDAY!
1 - 8 of 8 Posts
My new boat has a propane catalytic heater. When I turn on the heater it makes a buzzing sound but doesn't light. I don't see a pilot light so I assume it is electric start. The gas is on (the stove works).
Is anyone familiar with this heater? Is there a step I am missing? Does anyone have a manual? I haven't found one.
Thanks.
Andrew
· Member
Andrew,
Try tracing the propane hose back. There may be another solenoid or safety valve installed somewhere for safety.
Jim
· Senior Member
Surprised to read that these are actually vented heaters.. if so that's good news.
Do you have a manual? There's likely a 'proper' light-off sequence or procedure. Nothing online that I can see, but it looks like you could ask:
Services
Depending on the length of the hose, if it has not been used for a long time, it could take some time to purge the air out of the line. I would check that black hose to make sure it is rated for gas.
Discussion Starter · #8 ·
After some great advice from the manufacturer, I figured out that the blower fan was rubbing on the housing and that was causing it to not fire because of a safety feature. My wife is happy to have heat!
1 - 8 of 8 Posts
