1 - 20 of 51 Posts
Discussion Starter #1
So...in thinking about the huge forces acting on a sailboat in higher winds, I began to wonder what the real effectiveness of railmeat is. You've got maybe 1500 pounds on the rail at a pretty weak lever point - trying to counter acts TONS of force on the sail area and keel. Are these guys really making an appreciable difference? Or is this just more tradition than necessity?
What do you think?
I raced with a UK sailmaker. He would move crew around regularly, inlcuding keeping some on the centreline.
In really light wind you want crew to leeward to heel the boat. That will help keep the boom over and when going to weather a heeled boat is slightly faster.
When going downwind the crew is moved aft to facilitate planning and maintain the boats balance. I have seen fore/aft inclinometers in use.
Badger Sailor
Not just side-to-side trim ...
Yup, have to second what jackdale said. Paying close attention to weight distribution does play a huge roll in overall boat speed. We constantly move crew around as conditions and point of sail changes.
Using advice obtained here last winter, our overall performance this last season was much improved. :D Especially noticed during distance races.
I have definitely found that shifting everybody to leeward in light winds helps keep the boat moving.
I think another question about people on the weather rail is: does the benefit from keeping the boat slightly more upright exceed the drag due to extra windage?
Your not counteracting those forces, just keeping a small percentage from being lost. If you add just 1 inch per second to the boats overall speed that can add up to several boat lengths over the course of the race.
Smack, rail crew play a critical role in balancing a boat going to windward. They make a big difference. On windy days, we will collect extra guys whose only function is to sit on the boat (and drink beer and eat free sandwiches.) Fleets like the Farr 40 and some of the J’s have restrictions on number of crew members or max crew weights in order to eliminate the advantage of extra crew members. Cruising or sailing shorthanded is at a disadvantage insomuch as they can’t trim for speed like a boat with a full crew.
Seattle Sailor
Besides.... It gives us fat guys something to do and makes us feel important!!!
Discussion Starter #11
Okay, but....next stupid question...this technique essentially means you're counteracting the forces on the sails...correct? Couldn't you gain that same advantage (flattening the boat) with trim?
I can definitely see the need on smaller boats...but it just seems like a miniscule counteraction force on a big boat.
Special Delivery
I guess it depends on the boat. My current boat's keel weighs more than my C&C 37+ did. The boat doesn't move reguarless of where the crew sit. I went out to watch the boats in the St. Barth's Bucket race last year (must be 100+ feet to enter) and those megayachts had crew on the rail - maybe because it made for better photos.
Discussion Starter #14
I'm just trying to get AdamLein to throw down some equations! That dude has the mathematical goods.
I'm convinced there's more to the story here - and I think speciald is right that it's more about the photo than the physics.
Later, smack, I'm at work right now and I can only get so distracted by sailing before I feel like I'm not doing right by my company ;)
Ofcourse, meat resting on a windward bunk would do the same with less windage.
And of course, this is minor compared to small boats. On my first cat we carried two on the trapeeze, on hiking racks. The "rail meat" represented almost 80% of the righting moment. Failure of the rail meat to offset the forces involved were fun.
Weather helm is also a function of heel angle. Flattening the boat with railmeat to the optimum heel angle will reduce weather helm when going to weather, without reducing sail area.
When racers do reduce sail area they generally reduce the foresail first rather than reefing the main. That also reduces heel angle and weather helm.
Downwind the boat should be flat.
You can reduce heeling by trimming the sails, or by reducing sail area, but both of those methods reduces the amount of power being generated by the sails. The racer's preference is to keep the sails as powerful as possible, while maximizing the efficiency of the hull and keel. When you use rail meat to flatten the boat, you're improving the efficiency of the hull shape without reducing the power of the sails.
Rail meat accomplishes the same purpose on big boats as on smaller boats. It just takes more bodies on bigger boats. If the boat is heeling excessively when I'm racing, I'll put as many people on the rail as are available, even though they might not be enough. Every little bit helps.
If you have flattened the sails as much as possible, and put all your crew on the rail, and the boat is still heeling too much, then you have to start thinking about reducing sail area.
No offense to anyone, but all the answers are speculative and not quantitative. Sitting on the rail is really doesn't give you much advantage on a large vessel BUT where else should people be? On a properly run boat, people should not be all over the place.... just like on a football field, or basketball court. People have positions and should be there unless they need to be somewhere else. Since the weight has the potential to help, crew and gear should be positioned to keep the boat as flat as possible, if that is how the boat sails best. Like all the other answers, this is speculation without empirical evidence which I'd be really interested in seeing.
On small boats, I see the advantage to keeping the boat heeled in light air - to keep the boom in one place and to keep it from flopping back and forth. Ignoring the mechanics of keeping the boom in place, without exception, everyone that I've asked has not had an answer why the boat should be heeled. It makes no sense, less sail area is exposed to the wind when it's needed most. I'd really like to see a real answer to this since it's puzzled me for years. :confused:
On the same note, I question the radical elimination of gear to save weight. I once had crew get on me for carrying 20 gallons of water on an overnight race. One gal of water weighs 8.3 lbs. Then I looked at the guts on my crew......... Hmmmmmmm :laugher
There are other ways to flatten the boat then the use of rail meat. One of our friends at the marina has a real sweat racing boat. It's a 30' open with running back stays, full roach main and little to no comforts (doesn't even carry a cooler big enough for more then a six pack). But the boat moves, one day we were making 5.5-6 knots in 7-8 knots of breeze. Just don't take it out in over 12 knots of breeze with out 3-4 people that know what they are doing.
That boat has built in ballast tanks on the under side of the rails that can be filled for short handed sailing. There is a valve system that, with a pull of a line, will gravity dump the water from one tank to the other. It is tricky though. You have to be very quick and precise with tacking or you could knock yourself down and put the rail in the water.
Real fun to sail on that boat for an afternoon, but I'll take our cruiser for the long haul.
1 - 20 of 51 Posts
