Hello all,
What would your impression of the seriousness of below surveyor comments be? The survey also said the overall condition of the boat was very good and it was well cared for. I'm just curious if these are huge problems or typical and not necessarily needing immediate address....
1. The starboard side of the rudder has elevated moisture (20-25) on the top
two-thirds and a few vertical cracks with good sounds. These should be
inspected and repaired as necessary. The port side has good sounds and
good moisture (10-15) readings.
2. There is a two-foot by approximate 15-inch area of delamination or never-
bond on the port side of the hull bottom aft of the aft cradle pad and head
thru-hulls. This should be inspected and repaired as necessary.
Thanks....this is my first boat buy and I don't want to make a huge deal out of something that is not but also don't want to dismiss a potential money pit.
