Hi
I too have a Mac 25, your keel like mine is cast iron and it is a bit thicker at the bottom, might look bent in a photo. It weighs somewhere in the 600-650lb range, check the wire that raises and lowers the keel from the winch, also check the keel bolt and if the owner knows if or when it was replaced.
Good luck with the boat.
Anthony
