About 2 years ago I bought a new Tohatsu 4 stroke 6HP outboard, I think the same as Nissan & Mercury & same basic motor as the 4 & 5 HP. It ran/runs perfectly right out of the box, even at 6,000 feet elevation with no jetting changes.
HOWEVER, it has always been a bit "cranky" to start. I had many cases of it flooding, & tried many different starting procedures. I think I have finally solved the problem. The tank has a vent-in only cap. I think what was happening was that when trailering the boat pressure would build up in the tank from the gas being sloshed around, resulting in gas being forced by the float needle. Being lazy, I do not disconnect the hose each time I use it.
So, what I did was:
1. Cut off the one-way duckbill valve in the cap, allowing venting in & out of the tank, eliminating the pressure build up.
2. Only squeeze the primer ball just enough for it to firm up, no more.
3. Follow the starting instructions EXACTELY
Last two trips out, starts on the 2nd or 3rd pull, clean with no smoke.
Am curious if anyone else had similar problems & if so, what was the fix?
Paul T
So, what I did was:
Paul T
