Can't figure out why my outboard spring clip which holds the unit from tilting up won't engage. The little spring clip slips right over the pin that I assume it use to "hold' onto.
The result is when I put the motor in reverse the propeller causes the unit to swing out of the water. What an I missing? It use to work fine. Thanks for any help.
