Their website says it is for air cooled motors only. I called the company and a rep said he didn't know why the website says that and would not comment on that policy.How about once you get it clean, you could use the pre-mixed shelf stuff... like this:
Gets expensive if you use gallons worth at a time of course.
Ethanol free fuel helps...
Carb cleaner then air if available on the hook its not commonly available for meJets clog, but so do the passageways in the carb body. Carb cleaner is all fine, but compressed air is better.
My thinking is that if there is small crud like that on the throttle plate then it is likely it has made its way to the jets; so, yes, they have to come out and be cleaned along with everything else.The stuff on the throttle plate won't cause problems for the carb think small passages use carb cleaner and clean everything out twice hen blood it clean with carb cleaner again reassemble and run it
That doesn't change the fact that it can ruin your outboard.There are some additives that will help but not eliminate the problem. I suspect that this is your cause for issues. This information is a little dated but it provides the basic info, http://www.nola.com/outdoors/index.ssf/2012/12/higher-ethanol_fuel_starting_t.html . ChuckI sail in the corn belt of Illinois where ethanol is 'grown' - there are no ethanol free gas sources within hours.
Sent from my iPhone using Tapatalk
Interesting article, no doubt it is bad stuff. I can only speak for myself. I have had to use E!0 since it came on the market, around the early 90's, I think.That doesn't change the fact that it can ruin your outboard.There are some additives that will help but not eliminate the problem. I suspect that this is your cause for issues. This information is a little dated but it provides the basic info, Why higher-ethanol fuel will hurt anglers, and what you can do | NOLA.com . Chuck
Actually e10 has been around and in common practical use since the mid 1970's but back then it was called gasahol and not as well regulated as it is now daysInteresting article, no doubt it is bad stuff. I can only speak for myself. I have had to use E!0 since it came on the market, around the early 90's, I think.
Used it in cars, motorcycles, generators & outboards since then. Mixed with this:
Fuel Injector Cleaners, Diesel Injector Cleaners , Fuel Additives | Berryman Products
& draining the carburetor between uses has been problem free for me.
I change the gas in my generator once a year, the "old" gas runs fine.
Other additives may be as good or better?
Paul T
I was thinking that, it was around the time that lead free gas was introduced.Actually e10 has been around and in common practical use since the mid 1970's but back then it was called gasahol and not as well regulated as it is now days
