- Reaction score
- 1
In process of rebuilding plumbing system on my 31’ sailboat. Present system has a Y valve between the head and holding tank, which also allows the possibility to discharge overboard via vented loop-macerator pump depending on position of Y valve. The hose from the head is connected at top of holding tank.
The deck pump-out goes directly from the bottom of the holding tank and to the deck pump out. Another hose goes from the bottom of the holding tank via the macerator pump and connects to the overboard discharge line via a Y (not valve) right before the seacock.
The Y valve is a Forespar Marelon valve which is a pain, get stuck, broken handles etc and I am thinking of eliminating it totally by directing all waste directly from the head to the holding tank without any Y or Y valves.
To discharge the holding tank I would use one of the two existing outlets at the bottom of the tank to discharge overboard (when legally) directly to the seacock via vented loop/macerator pump (no Y)
The deck pump-out is already there on a separate line. With this system I would lose the possibility to discharge directly overboard, but when legally to do so can still discharge overboard from the holding tank. No more Y or Y valves.
I have looked and searched the net for a system like this but have not found any systems without a Y valve. Am I missing something?
