1 - 9 of 9 Posts
I have a similar version of the Groco raw water strainer in the picture below.
The fitting on the top - that top-hat with the three hole idents in it - is jammed solid and will not move.
Does it need some form of special tool to move it?
I have managed to clean it with a water back-flush but one day I am going to have to get the top off it.
It is an expensive unit. I really don't want to break it.
For those others that have a similar unit, beware the wee plastic drain plug at the bottom. It will snap like biscuit if you even slightly over-tighten it.
Thanks.
Super Moderator
Farr 11.6 (Farr 38)
I have no brilliant ideas except to gently heat the casting while cooling the top, followed by healthy doses of PB Blaster., Followed by turning the top with a spanner.while holding the casting with a oil filter wrench
If those techniques don't work then you might follow the advise from an old Harken video in which they showed how to install new ball bearings in a cam cleat using a credit card. The beginning of the video showed that there are 66 small ball bearings in a cam cleat. The narrator says that the easiest way to deal with a device that has lost its ball bearings is to use a credit card. Then the narrator walks up to a cashier in a store and hands them a new cam cleat and a credit card and says, "See how easy that is".
The video was actually an in-house gag and probably should never have been shown to the public. But there are times that you can spend a lot of time trying to fix the unfixable, and in reality, the easy fix unfortunately just requires a credit card.
(Don't get me wrong, I would try everything that you can think of. After all, I am the guy who refused to pay the ridiculous price being charged for a new ignition switch, and so spent a weekend machining a penny to replace the copper connector that had burned through due to arcing)
Finally, whether new or used, put some grease on those threads when you put it back together.
Premium Member
I replaced all mine with newer groco which has a plastic top. They suggest hand tight only. On the older ones I had with the bronze top like the one shown in the picture, I always used the Groco tool.
If you do it get loose, before reassembling, check O-Rings for cracking and replace if so. And ALWAYS coat the O-rings with Silicon Grease before reassembly. Remove the drain plug and check that o=ring also and replace if bad. Silicon Grease that also that needs to be drained before winterization. Do not use regular grease as it will destroy the O-Ring.
Gd luck
Nick
1 - 9 of 9 Posts
