1 - 4 of 4 Posts
Discussion Starter #1
I am trying to get my boat into the water but....
My trailer coupler was so bad it was a struggle to even attach it to the truck then the fluid cap snapped off.
So I pulled the old coupler off to replace it the brake line was zigzaged to compensate for it being too long.
I want to do the repair right. I am about 40 minutes from the nearest auto parts store.
Any advice on parts and specialty tools needed to make this repair tomorrow? I'll also need to bleed the system.
Hey,
What is your tow vehicle and how far do you need to tow and are there any big hills on the route? The reason I ask is that if your vehicle is large and the distance short I would just drop the boat in the water and then fix the trailer at a later date. I know that's not legal or 'right' but if you go slowly and have a large tow vehicle you will be OK.
To repair you don't need any special tools. A flare nut wrench is good to have but not really required. You will need to take pictures of the current line. Make careful measurements. Then go to a hydraulic shop or GOOD auto parts place and tell them what you need. Any decent shop will be able to make the brake line in a few minutes. It's very easy to bend the line, and flare the ends.
Good luck,
Barry
Discussion Starter #3
Hey,
That's what I did.
Boat is in dry storage with mast up. The road to the ramp is steep and narrow crossing a country highway just before entering the marina. I had visions of careening down the road across the highway.
WIth a 6 speed manual trannie I put it into 1st gear and barely had to touch the brakes. Boat is in the water, which was important as it was to be our home for two nights.
Our trailer popped a line somewhere on the Interstate. I now believe in surge brakes. I took measurements of the old lines then picked up new lines at a trailer part store. While only one line broke, I replaced all four to be safe.
1 - 4 of 4 Posts
