For better and worse my Contessa is basically stock all around - hank on jib, lines at the mast, no traveler.
While sailing upwind yesterday I was eying my main shape and lamenting the amount of twist. Without the traveler I had no real way to adjust it.
So I started messing around and what I ended up doing was rigging a large carabiner style fastener to cinch one half of the mainsheet down to the deck on the opposite side. This changes the geometry of the lines as they lead up to the boom end.
This is a good overview of my mainsheet and hardware:
And this is what I ended up doing:
First, on the left, is roughly the normal geometry when I'm sheeted in.
Second, on the right, is my new line in green with the black oval representing the carabiner style fastener looped around the mainsheet lines and cinched to an eye bolt on the deck.
The orange lines show the pull angle which can be thought of like a virtual traveler position. So the adjustment shown is like moving the traveler leeward, reducing twist.
Any thoughts on this idea? Better alternatices
The advantages are that it's simple, I can make up this line easily and stow it except when I want it. Unlike other things I mulled over (additional lines from the boom to the deck, two mainsheets) it still lets me adjust and dump the main from the usual place.
Of course the downsides are that it's an extra line that needs to be rigged, it needs to be completely swapped on a tack and it would increase friction on the whole system (which is already a problem).
Though I've seen plenty of Contessa's online with ugly homemade traveler contraptions and that's a direction I'm just not interested in going.
