1 - 20 of 28 Posts
I have a ST60 Raymarine wind instrument. The wind speed indicator suddenly stopped working, and the numbers were replaced by dashes. The wind direction indicator still works, as do the instrument lights. Very little info in documentation. Can I use a multi tester to determine if a signal is getting to the instrument. If so, how. Seems like the best place to start. Other trouble shooting methods?
As I understand it, there's a connector at the top, where the transducers plug into the cable? From what I've read, that's usually the problem.
You might try getting a DeoxIT and ProGold kit, treat following the instructions, and see if that doesn't clear it up. Sometimes those products work miracles.
Jim
this is why i replaced my ST60 gear... :)
Yeah, I know. Thing is: When you have other ST60+ gear, like we do (depth, knotmeter), it's the only logical way to go. But I'll be honest: Tho I'd like to have a wind instrument, I'm not pushing for it. I'm not pushing for it because: 1. I can't really justify spending even what the ST60+ wind instrument would cost and 2. Given the ST60's notoriously poor service record, I'm not inclined to push for even that.
So we'll live w/o it.
Raymarine's ST60+ wind instrument is a perfect example of what's wrong with American-made products these days: It's pretty obviously broken-by-design, and, just as obviously, Raymarine is disinclined to fix the design.
Jim
sounds like the motor in the wind-speed device at the masthead needs to be replaced or rebuilt. Can you get up there? Look online and you will find a shop that will rebuild the masthead unit motor. I had the same thing do down on my unit (I am drawing a blank on the brand) - I had an older unit and the manufacture went out of business. I was able to get it fixed online. It cost about $50.
Discussion Starter · #6 · (Edited)
AFTER going aloft and removing the instrument, I had the brainstorm to go to the Raymarine website (duh!!):p . They have a pretty good system for troubleshooting. It includes a simple test to see if the the transducer is supplying power to the read out (and vise versa), which is what I was looking for. Sadly, the transducer is in my hand! I could actually rig something up to test it in the cockpit, but it would be a hassle. Oh well, off to the shop to get it repaired. From the responses in this thread it sounds like the odds are good it's the transducer, but if it's not, I'll feel pretty silly!
Discussion Starter · #7 ·
To follow through on this topic. Raymarine didn't find anything wrong with the transducer. I remounted it, and performed the test referred to earlier in the post. It indicated the instrument itself had a problem. Sent the instrument to Raymarine and FINALY got it back (after several months and three phone calls). They fixed it for a flat rate of $199. Just installed it and I'm still looking at dashes (same problem)! I'll update when I figure it out. I can safely say at this point though, expediency and communication in customer service is not Raymarine's strong point.
I'd bet it is a wiring issue. Chances are pretty good that you've got a broken wire or corrosion between the masthead and the display. The most likely culprit is the deck fitting where you connect and disconnect the mast wiring when unstepping/stepping the mast. Have you tried connecting the masthead transducer directly to the instrument head.
Discussion Starter · #9 · (Edited)
Grrrrrrr!
Put a multimeter on the red connection of the instrument which supplies power to the masthead. Apparently, it should read 8 volts, it was reading around 2.93, same as when I first sent it to Raymarine! Only now, I don't have wind direction, which I did before!:hothead Sent them a e-mail yesterday, have yet to hear back. I can hear it now... "Well, send it back to us (In Massachusetts) an we'll be happy to take another look at it"!
Then..... I can imagine my next call; Hello, VISA?...about that $200 charge from Raymarine.....
I hope I'm wrong!
Discussion Starter · #10 · (Edited)
Raymarine/Customer Service?
Everything I've heard about Raymarine's customer service has turned out to be true. Their communication is terrible (often non existent!), and I've come to the conclusion they don't know how to fix their products. The funny thing is, the ST60 is a basic unit compared to what they are selling now! Anyway, I went round and round with them. They finally tried to blame the issue on the cable (of course, it was the only thing they hadn't worked on!). I was doubtful because the wind direction didn't work when I received the screen back from Raymarine (and it did when I sent it to them). I played along and went back up the mast and checked continuity on all 5 wires. All had continuity. Raymarine's answer was for me to send BOTH, the screen and mast head unit back to them (again)! I asked them if the wanted me to rip the cable out of the boat and send it as well so they could evaluate the whole package!:laugher I told them, forget about it, and to give me my $200 back! Until I replace the unit with one from another manufacture, I'll leave it in my console. I'll tell everybody who asks why it doesn't work about my experience with Raymarine's "Customer Service". In the meantime, when my rail starts going under water, I'll reef, and when the boat stops moving, I'll let out more sail and/or start the motor! But for now...I'm done with the instrument, and with Raymarine forever!
In the 6-7 yrs I've worked with RayMarine, i can't remember ever NOT getting connected to a competent tech on the 3rd or 4th ring.
I love their tech support..couldn't do without it.
Howard Keiper
Berkeley
Discussion Starter · #12 · (Edited)
OK Howard.... forget "Tech Support". When we thought the problem might be the cable, I called Raymarine to see if I could get a replacement. The automated system asked me if I wanted to leave a message or wait for a rep. After waiting about ten minutes for a rep, the automated system told me I had to leave a message:mad: , and that a rep would contact me within 24 hours. That was Wednesday of last week and I still have not heard from them. In THAT case, I was giving them a opportunity to sell me something, and they didn't respond. I take no joy in flaming Raymarine, I'm simply reporting my experience. I wish it had been different. I didn't spend all this time and money to still have an instrument on my boat that doesn't work. Nobody wants that thing to work more than me!
Look for a joint/splice in the cable, particularly near the base of the mast, it may be a small white box or just crimped and taped joints. This is probably to assist in unstepping the mast but invariably due to the location it gets wet and can cause similar problems.
Discussion Starter · #14 · (Edited)
The cable is continuous from mast head to display. If it did have a problematic splice/junction, I wouldn't get continuity would I (I did)? The other problem with the theory is that the display lost wind direction when the screen came back from Raymarine repair (it was only lacking wind speed when I sent it). While stranger coincidences have occurred, I think it's more likely that Raymarine screwed something up, as they claim they did fix a problem (didn't specify what it was). It went to the shop with one problem, came back with two....Hmmmm
Discussion Starter · #15 ·
Pulled the stick (for other reasons) and noticed the prongs on the head were far too short to connect with the female receptacle (didn't notice it when I was swinging 45 feet off the deck!). Apparently when I sent the head to Raymarine, they didn't put it back together properly and created another problem. Sent the instrument to them, they fixed it, but the system never worked right because of the bad connection. Gave up and found the problem 5 years later! Sent it to Raymarine, they fixed their screw up and the unit works fine.
Thanks for all this info. I will be doing some more debugging of my ST60 which has started doing the same - Dashes for wind speed but still has direction. This has recently started happening after 15 years of only a few problems. That said most of the buttons on the log, depth and wind are no longer working so I am migrating to a B&G system but was hoping to do the ST60's next year.
I just wanted to check if you manage to get the speed back as well as the direction?
I have similar but different problem with my Datamarine wind unit at present. Speed displays fine, but not direction. Direction does not move. But if I jiggle mast base connector, it may move to a new position. I did plug the masthead unit into the back of the head unit before stepping mast, and it 'seemed' to be working.
I always use deoxit when hooking unit up, but still likely have connection problems. There are three plugs. Masthead, Base of mast and Head unit. The Base plug is a high quality aircraft grade connector. Shouldn't be the problem, but thinking of removing and soldering wires just to see if that IS where problem is. If it is masthead, I know pins/sockets are clean. Maybe it is an internal wiring fault.
Over the years I have had numerous problems with this unit. I have more or less kept unit working myself. Once bought new cups and display covers from DMI. The LCD display gave up at one time, but I found it was a standard part and got one from local supplier (being soldered to PCB, R&Ring was interesting!) When speed became erratic, found oil had leaked out of head unit, so just re-filled.
It's become more a challenging hobby than a useful instrument ;)
Master Mariner
I can't for the life of me understand why anyone would buy a Raymarine product today, and therefore why they are still in business. I've gone through the same run around on the ST-60 TWICE and the unit still only works when it wants to. Only difference between the OP & I is that I didn't waste my time calling the total incompetents RM hires to frustrate customers who expect their customer service to help them.
Years of operating vessels equipped with RM electronics and I don't think I can remember any one of them that had all the RM gear working properly at the same time.
I guess if someone thinks saving a few bucks up front is worth the kind of frustration and disappointment the OP and so many others have shared about RM equipment on this forum (and others), then that will be their regretful choice.
Raymarine should sell their designs to a company with an interest in something other than the quick buck of the original sale, then quietly disappear from the industry.
1 - 20 of 28 Posts
