1 - 1 of 1 Posts
Discussion Starter #1
my velvet drive looses after twenty minutes traction and overheats.after i replaced the needlebearing behind the oilpressurepump that was blown to pieces.the loose needles i found in the oilchannels.is it possible hat something blocks the oilflow to the heatexchanger.i took everything apart but cold not find any fault.as far as i know flows the oil from the upper hose on top through the exchanger and returns on the righthand downside.the exchanger is cold and the gearbox very hot.can it be that the oilpump doesnt have anymore enough pressure because of the scratches from the destroyed needles in the pumphousing or did i make a mistake when assembling.there is one stainless steelplate lying on the bottom of the housing on top of the magnet.this plate i did not find in the explosiondrawing. is there any repairmanual online for the velvetdrive 10.18
1 - 1 of 1 Posts
