I could use advice from people who know about holding tank systems.
I'm aiming to install a new holding tank system from scratch. For whatever reason my 1976 Ericson 29 does not have one and does not appear to ever have had one... just two thru-hulls, one for intake and one for output.
I've done hours and hours of research and come up with this diagram of the waste system I intend to implement:
I think it should be OK, provided I can get everything to fit together and muster up the courage to buy 100's of dollars of components and drill a couple above-waterline holes through my hull. Though if anyone has any feedback or suggestions on how I am approaching this I'd be glad to hear it.
My biggest confusion right now is coming from how I'm supposed to connect the vented loop to the vent line. I'm planning on trying to use 1.5" sanitation hose for everything (including the vent line, which as I understand it, is better off thick to allow the holding tank more oxygen). However, the biggest hose any vented loop will accept on its vent is 1/2" as far as I can find, and the cheap one I would prefer to buy, has a measly 1/4" port with its adapter.
On top of that, it states that the valve has to be removed to insert the adapter. I researched and found that if you attach to a vent line, the loops are more reliable without the valve anyway. This is all fine and good, except that as far as I can tell there will now be sewage splashing up into the vent line every time I pump the head. This means, if I don't want to deal with terrible smells, I have to somehow find a 1/4" ID marine sanitation hose (which I can't find anywhere), AND adapt it to a tee connector on the 1-1/2" marine sanitation hose I plan on using for the vent.
I cannot find an adaptor anywhere that will let me adapt a 1/4" hose to 1 1/2", much less one designed for sewage. I can't even find a combination of adapters that would work; the closest I could get is this tee connector, and it's still three times too big.
Did part manufacturers as a whole really overlook a standard, widespread head configuration, or am I just blind, crazy and overthinking things (I suspect the latter)?
