1 - 7 of 7 Posts
My 1984 Beneteau First has a cast iron fin keel. The bottom of the keel has a void in it. The bottom of the keel currently has a flexible piece of metal (consistency of sheet metal) on it, and there is a split from front to back (again, on the keel bottom). Sorry, I don't have a picture to show as the keel is sitting on the rack and is difficult to get visual on it.
I am guessing that this void is due to galvanic corrosion. Here are a few questions:
1. Do you agree with my assessment?
2. If not, do you have any ideas what might have caused this?
3. Is this issue of a void common or very unusual?
4. For repair, should the material be ground back to the solid iron, smoothed, and then coated?
Thanks in advance for the help.
Old as Dirt!
Absent a photo, it is difficult to comment very intelligently, but you may be looking at a former mounting for a lead shoe that has since been removed. Lead shoes or a "sabot" were in vogue in the late '70's early '80's as a means of increasing ballast, lowering a boats CG and adding "stiffness". In any case, Beneteau cast iron keels are quite robust and easily repaired/reconditioned.
FWIW...
Discussion Starter · #3 ·
Thanks for the response. Then, maybe it isn't galvanic corrosion. Guess I'll get the angle grinder out and start exploring. I can get to some of the keel bottom to, at least, grind through the "loose" metal that looks like sheet metal. Maybe it is a piece of sheet metal.
One of None
Hunter 34
Geeze.. get a camera! Sounds like a serious issue!
1 - 7 of 7 Posts
