Setup: House bank of two 6 volt golf cart batteries wired in series. Few years old, good shape. Boat has very low amp needs. Starter battery: 7 year old Napa Grp24 dual purpose, used to start a 22 hp Vetus Diesel. Batteries separated by a Blue Sea Charging Relay and Switch. Wiring is 4 years old 1/0. Appears clean and tight.
Symptoms: Starter slow, or intermittently does not engage. This has been going on for the last two seasons. Bit worse this year.
Tests: Start battery at 12.6 or 12.8 volts between posts. When cranking, voltage drops to low 10's, possibly high 9s. Combining house and starter batteries using the Blue Sea switch does not help. Having fully charged batteries does not help.
Where is the problem?
1. Battery? Starter battery at 7 years old certainly is on its last breath. However, I've had it load tested and they tell me it is still fine. And, combing batteries does not help. I believe house batteries to be fine, though I've not checked them recently. Symptoms persists with all batteries fresh off the charger in the spring.
2. Wiring setup? I've got a 150A Blue Sea BusBar for the various ground wires. The ground from the starter connects to this Busbar, with a separate wire to the negative stud on the battery. Could I be loosing voltage though the busbar? Better to connect starter ground directly to battery?
3. Poor Connections? I did this wiring myself, using good quality 1/0 wiring, and an Anchor Lug Crimper and a vice, with heat shrink over the joint. Do I simply have a loose/bad connection?
I'm aware that there are more indicative tests to help find wiring issues specific to which circuit, but in my situation they require longer leads on the multi-meter, and three people, which I don't have at the moment.
I'm thinking there's a connection issue, but I'd love to hear from the experts on this.
Preserved.
Preserved.
