Warning! New filter system on new Yanmar engines is Bad!
14280 Views 60 Replies 19 Participants Last post by  gibbo90909
Hi folks,
I got into a very serious problem the other day.
I have a new Yanmar 4JH57 the new common rail engine. 300 hours on the clock. It has a new pre-filter replacing the Racor 500. The inlet on the new Yanmar pre-filter has a Banjo bolt where the fuel must turn at 90 degrees and go through a hole in the bolt about 1mm wide.
This turn gunked up and the engine stopped.... in a remarkably difficult and dangerous location with a contrary current of 5 knots and me being only able to sail at 1.3 knots - directly towards the rocks!!! With another 6 hours of current sucking me into the infamous Alderney race with currents up to 9 knots.
If it had stopped 15 minutes later there is no way I could have turned around and been able to sail into the current.
So I had a fun few hours trying to sail and locate the fuel fault.
Also the filter needs a spanner/wrench far larger than I have so I couldn't change the filter at sea!
On a brand new engine its not expected to stop!
Anyway I finally traced it back to the Banjo Bolt and its tiny hole. A tiny piece of orange plastic has gummed it up then crap built up around it.
I though a pre-filter was meant to suck anything out of the tank and filter it before the primary fuel filter mounted on the engine.
I do not want / and will not have this possible situation again. Cruising boats can often pick up dirty fuel (I've fuelled in Venezuela, Egypt, Oman, Indonesia, Malaysia etc) or some goop can get in or grow, no matter the additives etc.
My solution is to buy a new Racor 500 as a pre-pre-filter and to mount it in the aft cabin on the external riser for the bunk, adjacent but on the outside wall to the Yanmar filter. Thus I will be able to ensure gunk the size that blocked the Banjo Bolt will not cause a problem, and that I can visually see the Racor from the Saloon, and change that Racor filter in less than 1 minute.
I found the problem and cleaned the Banjo Bolt and was able to get back to harbour no problems... but by then another bit of gunk was in the bolt.
I pumped out the whole tank and filtered the fuel and its clean as a whistle.
I will upload a pic of the problem off my phone in a few moments... but heres a location snap of exactly where you do NOT wanna have the engine clag up.
Your comments appreciated.
Mark
See less See more
41 - 60 of 61 Posts
Pre-filtering by Baja Filter and gerry can is difficult... have you ever tried to hold a 5 gallon/20 litre gerry in the air for a few minutes? No gym needed that day, :)
Reactions: 1
Jug tied to stanchion or line, syphon into tank with length of tubing, rag around tubing at fuel fill to prevent water ingress.
Syphoning is not fast but is easy and safe.
The new Racor going in.
The first photo shows the position in the aft cabin. Yes some guests might find it a little inconvenient...
The second pic shows the view from the Salon. I can keep a casual eye on it anytime. Plus I don't need to move cruising junk and the mattress to change filters.
See less See more
2
May want a simple box to cover that if you have any drunks, sleepwalkers etc aboard. Just velcro would work
What works for you is whats best.
Reactions: 1
Great idea!
Merci. :grin
You probably know this, but the 500 comes with and without a metal cup under the clear plastic bowl. I understand the metal cup is necessary, if mounted in the engine compartment. I'm really not sure if it's to deflect heat or catch a drip. It's nearly impossible to ignite dripping diesel fuel, unless a fire is already raging, in which case, I don't see the cup helping. :eek
The metal cup is actually called a "heat shield." I believe that they are an ABYC requirement - too lazy to look it up. I don't have one on my boat, and they are STUPID expensive (like $150) for a $2 piece of stainless.
Reactions: 1
Mark, good to see the hoses run straight in and out of the filter, radiused turns with no crappy 90 deg fittings to catch any crap that may be in there with the fuel. :):)
Reactions: 1
I looked through the ABYC standards. The two most pertinent standards are H-33 "Diesel Fuel Systems," and P-4 "Marine Inboard Engines and Transmissions." NO MENTION OF A SHIELD REQUIREMENT FOR THE FILTER BOWL.
There IS a USCG requirement (USCG and EPA Compliance Guidelines; Fuel and Emissions) for inspected vessels that every part of the fuel system must be able to withstand 2.5 minutes of exposure to a heptane fueled flame. The temperature within one inch of the (bottom of the) component under test must reach 648ºC at some time during the test (now you know why these shields are so close to the filter bowl).
The need for the shield, which could hold fuel, to deflect the heat makes the use of it seem like a BS requirement to me.
There is also a requirement that any fuel pump be located within 12 inches of the engine, with the only exception being if the pump is used to move fuel between multiple tanks. I don't meet this requirement either.
See less See more
Reactions: 2
Mark ....
Sorry for your problem.
The 'best' way to deal with this and to prevent fuel gremlins from exposing themselves at the exact WRONG time during 'serious' travel (ie.: crossing a bar, or entering a busy port channel, etc.) is to install an independent fuel recirculation polishing system that also constantly delivers to an independent 'day tank' of 1-2 gallons to a small 'day tank'. This will enable when SHTF of the fuel system, one can quickly 'open' the contents fo the day tank directly into the lift pump and keep going for an hour or two with a high probability of ultra clean fuel .... enabling one to get to a safer place and then assay the system properly.
The recirc system (for an engine of your size/hp) is simply a 10" long by 2.5" diameter (industrial type - steel) filter housing, an independent 12vdc Walbro-type pump sized to totally 'turn over' the entire contents of your fuel tank at about *2-3 gallons per MINUTE* per 100 gal. of tank capacity. Retention size of the recirc. filter should be 'open' to allow for the *largest possible flow rate* ... about twice the retention µM of your 'main'/workhorse fuel system filter (usually a 10µM). That ~20µM filter in the recirc. system statistically will deliver the particle count to MUCH less than 10µM as it will constantly deliver the fuel over and over and over through the independent recirc. filter (from the tank, pump, back to the tank ... and day tank) any time the engine is 'on'. My current recirc. pump system using a 15µM depth type spun bond polypropylene filter sometimes maintains 'sub-micronic' levels of fuel particles.
The day tank (1-2 gallons) arranged high in the engine compartment, and with LARGE as possible hose/tubing to prevent flow resistance, so that no pumping needed to deliver to the lift pump .... all 'work' done by gravity, once the bottom 'kock-valve' plus atmospheric vent valve of the day tank is opened. .... then you'll have about 1-2 hours of run time before you 'have' to find the problem. A clean-out 'hand hole' needed on the day tank for routine inspection and cleaning of bacterial/fungus.
Racor offers self contained recirculation polishing systems for the LARGER boats ... youre required to sign a mortgage. Simply follow the Racor advertising sketches and build your own ... for a minimum constant 'turnover' of about 1-2 gallons per minute per 100 gallon tank, at ~15-20 µM using a 'depth type' cheapy filter element and 'steel' filter housing - Home Depot stuff.
FWIW In the tropics or far 'outports' when I pick up bad fuel ... usually very fouled with tank wall crap from delivery barges in heavy seas ... I can 'usually' return to visually clear** (less than 5µM particles) in about an hour on a 100 gallon fuel tank ... sometimes using several depth filters.
FWIW2 - If you put fuel into a clear glass container, hold it up between your eyeball and the sun .... any denoted 'haze' indicates particles greater than ~5µM. I usually visually test all fuel going into my tank ... using a 6 ounce clear water glass.
FWIW3 - the absolute simplest remedy is to install a 2 valve block and bypass 'around' all the Racor train, etc., and when the engine stumbles simply open the block and bypass to operate 'briefly', with NO filtration, until youre in safer waters - "chancy" but will work 'briefly'.
Another suggestion is to install a 12vdc vacuum switch assembly wired to an 'alarm' to your main fuel system - one wired vacuum switch between the lift pump and the so-called primary filter. The differential pressure set point should be set for 10-15% lower than the RAcor's operating CHART (flow rate in GPM vs. differential pressure - psid across that filter) with your engine running a 100% rpm / WOT. Youll also know (by alarm) WHEN to soon change out your main fuel system filters. If thats too much, put a simple vac/pressure gage between the filter train and the lift pump ... and routinely monitor it with the engine running at WOT ... simply check now and then if the vacuum gage is showing a noticeable increase or the correlation to ∆P on the Racor *flow vs. ∆P chart* is now at 90% of the required fuel flow to keep your engine running at wide open throttle - WOT
Of course, you should be 'dosing' with Biobor™ for antibacterial and antifungal control.
The problem with small pieces of 'crap' ... chunks of bacteria (mini-strings)/funguses/plastic etc. debris is that they offer 'sites' where even teeny particles can begin to 'bridge' onto the small piece of crap and can set off an exponentially 'fast' full blockage of the fuel system. In industry, any foreign object at greater than 1/4 the diameter of the diameter of the tube/hose can cause a rapid complete blockage .... as most of these particles in most liquids are electronically surface charged ... they 'clump' together.
hope his helps.
See less See more
Reactions: 3
Thanks @RichH I will read that again tomorrow.
Pictures are better than words. This is from ~1995-2008. Component part numbers need updating, etc.
Other suggestion, that 12vdc 'bleeding' pump in the upstream probably should be replaced with a 12vdc full-on diaphragm-type pump plus 3 valve block & bypass ... as a backup for a failed engine lift pump - not cheap.
... Plus, that pump in 'pressure feed mode' and an emergency scenario will add about 6psi to the fuel delivery system ... you'll realize the value of adding 6 psi to the fuel system when you carefully scrutinize your Racor filter's flow chart diagram (GPM per PSID) ... more additional flow through a partly clogged filter !!!!!
Note: pressure feed is for fuel systems monitored constantly by a marine engineer, as if you have any piping, etc. failures with pressure feed on the system, you are vulnerable to filling the bilge and overboard in a hurry. All pressure feed systems should have double flared connections (NEVER with 'compression' fittings), and well rated pressure service design for the entire fuel system .... plain rubber hoses are strictly 'verboten'. Pressure feed systems rarely need air purging or 'bleeding' to affect a 'restart'.
FWIW - the common fuel system design on recreational boats are specifically designed to FAIL EASILY ... any time there's a fuel system failure, a vacuum feed system automatically 'sucks air'; and, instantly shuts down the entire fuel and engine system, usually with no oil leaks into the bilge, etc.
See less See more
Thanks! This two year old post saved me a LOT of time.
Engine quit unexpectedly, did a quick search about these "new-to-me" filters and found this post. Sure enough, I had the same problem.
Thanks! Seahawk on the Chesapeake.
139934
See less See more
Reactions: 3
Its the racor filter hardware thats super $s.
Generic replacement filters are inexpensive.
The 500 is very user friendly....and proven.
Im sure there are others that perform as well and are much less $s.
Post a link to the one you like
139936
See less See more
Glad I could be some help! ? ? ? ? ?
And honoured you joined just to say "Thanks" ☺
Mark
Reactions: 1
Font Magenta Pattern Number Parallel
No plastic bowl without a heat shield has ever passed this test that I'm aware of. Racor does not claim that they do.
See less See more
I have dual raqcors and when I replaced my pathetically installed fuel tanks a couple of years ago I had them built with bottom feed (no pickup tubes). Nothing sits in the bottom of my tank but diesel, it's all caught by the Racors.
PS. No heat shields on mine, I like to see the condition. One of the few places I disagree with ABYC. If your fuel filter bowl melts .... You got bigger problems any way.
Reactions: 2
I don’t have heat shields on mine either, but they are in a cabinet outside the engine room. Does that ABYC quote apply regardless of where they are installed?
Thats the way I read it but It's one that I choose to ignore on my own boat..
Reactions: 1
Are you thinking of the full metal bowls instead of the heat shields? The heat shields allow one to fully see the inside of the bowl. I agree that they are a silly requirement. At most, the shields may slightly delay a bowl melt as long as they were located well above the source of heat.
Mark
Mark
Nope, I am talking about the shield. I find that most installations have the filters so close to the deckhead they have me putting my forehead on the filter to see whats at the bottom of the bowl. I have a hard time focusing at 3" :)
See less See more
Reactions: 1
41 - 60 of 61 Posts
