Have you wasted big money on the wrong solution??
Cruising world wide theres different propane/Butane and mix or propane and butane in different countries... and the regulators and fittings are different. Though you can put Butane in a propane cylinder (or visa versa) many countries dont allow it, don't have the fittings, or only do Swap-and-Go.
So... I have a full UK Propane tank in reserve that I will not use before heading to sea.
My French Butane/Propane mix tank is called CampinGaz.
Thursday night just at the end of cooking dinner I saw the flame drop so the tank is empty. I changed to a new full CampingGaz cylinder and turned the stove on briefly to make sure its worked. Maybe 10 seconds (remember these facts, Sherlock!!!!!!!!!!!!)
Next morning turn the stove on and just a spluttery flame comes out. I think it must be some air bubbles in the hose and run it for a few seconds with GF worrying about gas smell.
I decide the tank must be at fault, check it and the rubber O Ring looks different to the old bottle. I walk them both to the shop and get 2 full ones.
Back to the boat, new gas bottle on and same thing happens!!!!! Bad flame on each element and in the oven.
It "can't" be the same problem with 2 different gas bottles!!
Might it be the Regulator?
It "can't" be 2 problems occurring at the exact same time.
OMG the $1,000 stove is kaput?????
To check the the stove is bust I plumb the UK Propane cylinder in and it works!!!!!!!
Thus it MUST be the regulator. No problem they are about $14.
But thats the OLD regulator. France/EU has gone to an new $120 regulator!!!
Which needs new connections!!! $30.
So I pay out my money...
So I plumb the new Regulator in. Same fault!!!!!!!!! Gas is wrong, spluttery, unsafe etc etc etc.
Its different gas bottles.
Stove is OK as the UK Propane worked on it
Same fault with both regulators. so the regulators are not the problem.
You worked it out yet??
The 2 CampinGaz tanks filled in the same batch have both be overfilled giving a higher gas pressure through the regulators (!!) and causing the spluttering.
Solution: Hold the button in for 10 minutes and keep the cigarette lighter on until some gas is used...
A waste of half a day, 4 trips to the marine shop and about US$160
Make me feel better with your disaster story
Mark
Mark
