In the course of doing some research for a replacement hot water heater I had pretty much settled on a 6 Gallon SuperStor made by the "Heat Transfer" company as it has a very good rating for heat retention. Doing a bit of research on that unit however (as electrics are not a subject I'm too expert with), I came across a posting on the BoatUS website concerning the unit (BoatUS Ask the Experts) in regard to the use of solid copper wiring rather than flexible stranded wire. Considering the ease with which solid copper wire can be broken when flexed repeatedly (as on a yacht), and the fire hazard a "hot" broken wire would present, that unit is now off my list of possibilities and I thought others might like to be made aware of the matter for their own considerations.
We just escaped a potentially dangerous situation with 120v AC wiring to an air conditioning system (see http://www.sailnet.com/forums/gear-maintenance/107849-air-conditioner-hazard-potential.html) and I do not want a repeat experience with a hot water heater.
FWIW...
FWIW...
