I have been helping a friend with a watermaker issue and we are stumped. His flow rate went way down and his PPM went way up. The watermaker manufacturer told him his membrane was shot, sounds reasonable, had another one shipped to Georgetown, Exumas. The new membrane had the same issue, we can get the pressure up to 800 PSI (with the valve is fully closed) where my WM seems to have lots in reserve, but the output is down to about 6 gph vice the 20 gph it should be and PPM stil way too high. The manufacture is saying it must still be the membrane, shipped another in, the same issue!!! Thought maybe it is a pump issue, took apart the valves and they seem to be working as one way valves when blowing through them. Didn't go any further with the pump and don't have another to swap with.
Any ideas? Could the pump not be working right even though we can get the pressure up to 800 PSI (barely though). It had too much oil in it, could that have gotten into the system and mess a membrane up very quickly, yet cause the output to be low?
thanks
Richard
thanks
Richard
