Hi, I am trying to get a rough estimate of the weight of a keel in a sailing yacht. Is it correct to get an initial value by taking the weight of the keel as a percentage between 35% and 45% of the total displacement?
Thank you
Thank you
Modern design? Boats this big rarely have 40% of their weight in keel. More like 20 to 30%.Thank you for your replies.
The boat I am considering is a 30metres long cruising sailing vessel with an approximate displacement of 150tonnes.
Displacement (light ship) approx………. : 99.6 tonnes / 219,580 lbs
Ballast…………………………………………… : 28.5 tonnes / 62,832 lbs (including steel fin fabrication)
Keepin mind the 99 tons is lightship weight. Just in fuel she will ship an additional 9 tons and water is an additional ton. Outfitted weight could be substantially higher.From Stumble's link.. A 28% ballast ratio on a modern 100+footer. Looks like Kriss nailed it!![]()
