1 - 6 of 6 Posts
Discussion Starter #1
Gearing up for my annual maintenance on my Westerbeke 30Bthree.
One task I have not yet tackled is replacing/flushing the coolant - I have had the boat coming up to 4 years, and have not done this before. I have also noticed some rust in the expansion tank, which makes me think a good flushout would be a good idea. Any best practices?
I was thinking disconnecting the hoses to the heat exchanger would be a good place to start - I can find no obvious drain plug...
Does your Westerbeke service manual actually suggest changing the coolant and at what interval? Also what type of coolant is recommended? Many new diesels require Extended/Long Life coolant such as Dexcool, very important. Changing your coolant might not be necessary.
Even dexcool has a life of 5 years, so 4 years is close to due.
The best coolant to use is not dexcool, but one of the newer universal extended lifetime ones, like prestone extended. They are a hybrid of organic acid (dexcool) and older technology.
Use distilled water to dilute, or buy 50/50 coolant.
I did a bit more research, and Prestone Extended is a organic-acid technology coolant (OAT). I would be more happy using a hybrid (HOAT) coolant, and the easiest one to find on the high street is Valvoline Xerex G-05.
Discussion Starter #5
FYI, in researching this I came across this article from MaineSail. It outlines some of the steps required - seems a bit of a pain to remove the heat exchanger to replace the collant, but unless somebody has any easier suggestions I guess that'll be the path I follow:
If changing antifreeze, the best thing to do, especially if your engine had or has "Death-Cool" in it, is to thoroughly flush it out, clean it, and start fresh.
To do this on a Westerbeke;
1- Remove t-stat and replace cover housing using a spare gasket
2- Remove HX (might as well clean and have pressure tested)
3- Purge old AF out of engine with pump into 5 gal bucket.
4- Use an acid resistant pump and circulate Rydlyme through engine block to clean cooling passages
4- Flush Rydlyme with water then fill bucket with distilled water and circulate through engine
5- Drain off what you can of the distilled, replace HX, t-stat and add antifreeze. The "Globals" are good. Death-Cool (AKA Dex-Cool) does NOT like all the dissimilar metals in marine engines and can create Dex-Sludge.
Death-Cool Sludge:
http://www.pbase.com/mainecruising/image/108349271.jpg
6- Purge air and test AF concentration with AF tester..
Circulating Rydlyme:
http://www.pbase.com/mainecruising/image/122459307.jpg
Connection points:
http://www.pbase.com/mainecruising/image/122459310.jpg
For air purging I replace the cheap "pet ****" on top of the t-stat housing with a 1/4 turn ball valve. I then add a barb and some clear hose to it. Run the hose well higher than the highest point in the cooling system. Fill the hose with AF using a transmission funnel, open valve and start engine. As the t-stat opens and closes AF will gravity feed into engine and no air will be left in the system. Air=bad. Once the system is no longer taking AF out of the clear tube close the valve and drain the hose back into the AF container..
Air Purging Valve:
http://www.pbase.com/mainecruising/image/112297123.jpg
Wow. Lots of work. Like I said confirm that it actually needs replacement. Fleetguard makes test strips that I purchased on Amazon, or I'm sure you could send it out for testing. I have my oil analyzed for under $20. Also I believe the Longlife coolants can be refreshed with a bottle of additive. Some of the auto dealers(Ford? Chrysler?)sell it for the diesel guys. I think the key with the Dexcool or the like is that it hasn't been contaminated with regular coolant. The test strips will show that. 'IF' your engine has Dexcool.
1 - 6 of 6 Posts
