Here are your numbers Minsy. O.K., now tell me what “ARE” stands for. Also, you will have to eventually tell me what your boat is (so I can update my database). Length is increased in the “middle” of a boat (not the ends) so it takes a certain amount of LOA before a boat grows into its ratios. Congratulations Minsy, it’s a cruiser! (your moment of inertia is the classic number for cruisers)
DSP to Length = 232.1 (200-300 is “cruising”)
<O
Sail Area to DSP Ratio = 16.6 (Most boats are between 16-18)
<O
Hull Speed = 7.88 kts
<O
Velocity Ratio = 1.07 (under powered is less than 1)
<O
LOA to Beam = 3.28 (“fine” is 3.5-4)
<O
Capsize Risk = 1.77 (over 2 cannot compete in ocean races)
<O
Comfort Ratio = 30.48 (cruisers are 60+)
<O
ScottyT, your Hunter numbers aren’t bad either albeit, you do suffer a little from the “under 30’ syndrome”. Your numbers are almost a scaled down version of my 34. I’m assuming that this is one of those Chernubli (sp) Hunters? Do you race, and if so, how well do you do?
<O
Once again, this is not a Catalina of any stripe (I’ve checked). Nor do I think it is a Com-Pac on the account of the beam dimension.<O
