1 - 20 of 29 Posts
I thought of this yesterday as I was cleaning up after helping a friend do a bottom stripping job and while I was standing in the shower and trying to clean all the blue dust from my face.
As anybody who has sanded off any bottom paint knows, its a dirty job; one that requires a proper resperator and eye protection. But no matter how much protection you have for your lungs and your eyes, the blue dust gets everywhere. The clean up of your face can be a job in itself.
I was thinking as I showered yesterday, what if I had applied a thin layer of Vaseline to my face before I started working. I would think the film of gel would have aided a great deal in cleaning when the work was done.
Has anybody tried this? What do you think? Dumb idea, why bother, or hey that sounds like it might work?
Please, only those who have been there respond. If you have never been under a boat sanding off multiple layers of bottom paint, in my opinion, its something that every boat owner needs to experience. Than try and clean up.
..........huh?..
I thought of this yesterday as I was cleaning up after helping a friend do a bottom stripping job and while I was standing in the shower and trying to clean all the blue dust from my face..
Wow, you gotta read that first paragragh carefully. You were helping your friend work on his boat, right?
Discussion Starter · #4 ·
Would it have made any difference if I forgot to mention that the friend was a female?
I used a painters suit with a hood purchased at Northern Tool. This along with a painters stocking cap worked well and I never had a problem with gtting the dust on my skin.
Basically, Sailchick recruited him and Sway into helping strip the old bottom paint off of her boat...
I keep telling them that they need to get the full face respirators and look like a bad B-grade scifi movie cast extra with their tyvek suit and full face mask, but no... they have to be macho and get the blue paint all over their faces...
TJK/Sway-
You really need to invest in one of these:
photo courtesy of riogrande.com
Discussion Starter · #8 ·
How much is one of those things?
And btw, don't tell sway about this. He said the chemicals didn't bother him. I think his brain cells are too damaged to notice the difference. His response will be, whats the big deal.
Somewhat Senior Member
I think Dog's answer is the correct one but I will share this. Long ago I worked for a tire manufacturer in a part of the factory where airborne lampblack was a problem. It got everywhere including face and hands. Clean up was accomplished by using pertroleum jelly, and the wise workers would pre-treat with before his shift to make after-work clean-up easier.
Discussion Starter · #10 ·
So Im not that crazy.
Thanks MGM. I agree, Dogs full face respirator looks a lot better.
TJK—
About $120 for the full face mask... well worth every penny though IMHO. Far more comfortable than goggles and a half mask, since the googles let more dust in and fog up to boot.
If used properly, with a tyvek hooded bunny suit, you don't have a whole lot of clean up to do... :)
I personally try NOT to think, as it usually pulls my pea sized brain muscle.
But if I had to choose, the mask would be first, not sure about vasoline on my face or not, but there are some gels you can put on your hands if doing auto work that will keep motor oils or equal from getting into you skin really bad, so I would imagine that there is some similar products you could do to protect your face, and make the scrapings and sanding particles come off easier. Whether vasoline is the best product or not......I'll let someone else think about that one!!!
Just to answer your question though, yes the vaseline will help create a barrier against you and the dust layer. Experiment with hand cleaners to see what dissolves it the best before you help again. good when painting too for those nasty oversprays.
It's very interesting how things differ from country to country.
I can't think of a single hard-stand anywhere in New Zealand (or South Africa for that matter) where they would allow you to dry-sand a boat. If you did, they would insist that the boat be completely enclosed in a structure of some sort or that your sanding machines are fitted with strong vacuum extractors.
Every vessel that gets sanded here (NZ) is wet-sanded, the run-off is trapped by temporary dams and the dust swept up when dry. Run-off that makes it past the dam is washed into drains that are located around the complete perimeter of the hard-stand and flushed through filtration systems before going into the drainage systems.
Maybe that's why the water off the US is so beautifully torquoise.:)
Courtney the Dancer
The last full face respirator I bought was around $200. A fiberglass guy I know uses a hood with a clear shield you look through, and it has a hose that attaches to it that supplies fresh, clean air so you have positive pressure inside that keeps all the dust out. I don't know the brand or the cost, but that is what I am using next time the bottom needs sanding, and a tyvek suit of course. I'll see if I can find something like it and post a link.
Courtney the Dancer
$800 for the hood and air line and electric pump. A little spendy for something that isn't going to be used all the time, but if 3-4 people split it, you are down to the cost of a full faced respirator and you don't have to buy cartridges and a lot more comfortable, and you don't get that toxic dust all over you.
Allegro Safety Supplied Air Respirator System-One Man Hood
Courtney the Dancer
Omatako- I don't know about other parts of the US, but any sanding of bottom paint here (PNW) has to be done in an enclosed area with a tarp underneath so all dust can be picked up and properly disposed of. If you are not in a building you must build a tent around the hull with tarp underneath. Pressure washing the hull is the same as NZ, all run off is sent through a filtration system. Sorry to ruin your US bashing, but the US has some of the most stringent environmental laws in the world.
1 - 20 of 29 Posts
