thanks, its a william shaw pearson 36. that's all i know at this point. also, what would you recommend as the maximum draft for exploring the bahamas and keys.
Others will know better than I, but I believe the general rule is that while less is best, a max draft of 5 feet is not too restrictive.
btw other specs:
LOA 36.5
LWL 29.6
Disp 15,000/15,850
Ballast 5800/6550
SA 665 sq ft
SA/D 17.49
D/L 258.73
Whatever you do be sure to view the boat in question first hand before committing to anything, and arrange for a proper survey before proceeding further.
For an owner to have so little knowledge of 'his own' boat is rather frightening.
Designer Shaw Main Area 244/285 Hull Speed 7.29
First Year 1972 For Tri 341/370 SA/D 16.5/18.5
Last Year 1976 I 46.0/50.0 D/L 233
LOA 36.5 J 14.8 BR 39%
LWL 29.2 P 38.0/44.5 L/B 3.30
Beam 11.1 E 12.8 LWL /B 2.67
Disp 13,500 Eng D/A4 OR 19%
Draft 6.0 # Built 103 CSF 1.80
Sail Area 585/655 MCR 29.6
Ballast 5,800 M/F 0.71
PHRF 138
All the Pearson 36s I've seen have been fixed keel. The Pearson 35 however is a keel/centerboard with 3'9" draft with the board up and 7'5" with the board down. The 35 sails and balances well and is a very sturdy boat. I've had mine in several gales and it does well. The only difference I've seen between the 36 and the 35 is the 36 has a pilot berth along the engine area and it's about 2,000lbs heaver. The 35 is listed as a coastal boat but I would't be afraid to take it anywhere.
The original Pearson 36 was built from 1972-1976. The Pearson 36-2 was built from 1985 - 1991. These are completely different hull designs. The P36 had a skeg hung rudder and drew 6 feet, and the P36-2 had a spade rudder, and a choice of fixed or swing keel.
First year P36-2s were predominantly fixed keel with a 6.5' draft. Most of the swing keel P36-2s (4.2' draft) were built after 1986. A few P36-2s after 1988 were equipped with a wing keel, and had a 4'9" draft.
The Pearson 35 was built from 1968-1982. All of them had a swing keel and draw 3.8' with the board up.
Best to find out which YEAR that the boat was built (it will tell you which model you're dealing with), and then determine the draft. The model year is indicated by the last two digits in the HIN.
We own a Pearson 36 Mk II built in 1985 that we have in charter [EDIT] in Southern FLorida and the Bahamas. We made many upgrades to the boat for charter, plus just needed some new stuff after many years of use. Great Boat! Worth refitting if needed. We invested $50k in refit because we love the boat so much. Now she is like new.
Jay
1 - 10 of 10 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
A forum community dedicated to Sailing enthusiasts. Come join the discussion about sailing, modifications, classifieds, troubleshooting, repairs, reviews, maintenance, and more!
