1 - 12 of 12 Posts
Learning the HARD way...
That appears to be an EPIRB. It would be good to know if it is the current generation (in which case it is worth something), and if it is registered.
Uh, I found this with about 1 second of Googling;
Personal Water Activated 121.5 MHz EPIRB
with In-Line Speaker
>Perfect for use as Crew-Overboard system when combined with
VectaTM2Direction Finder
>In-line speaker emits audio warble to confirm activation and
transmission of distress signal or to notify of accidental activation
>Exclusive ACR audio indication of transmission allows effective
self-test
> User-replaceable battery unit uses inexpensive, easy-to-obtain
common lithium camera battery Duracell DL223A (or equivalent)
>10-year storage life lithium battery
>Frequency stability exceeds ETS 300 152 standard
>Output 100 mW nominal (ETS requirement is 75 mW)
>Floats if dropped overboard
>121.5 MHz (SAR frequency) provides rescue forces with pinpoint
homing
>New, durable, stainless steel antenna is automatically unfolded
via quick-release antenna trigger
>Compact size with antenna folded; durable double-braided antenna
resists distortion when packed for extended periods
> Multiple lanyards allow many secure methods of attachment
>LED indicator confirms transmissions
>Diamond knurling on case improves fit and security of grip
TM
Material: Fiber reinforced polycarbonate blend with resin tougheners
Color: Hi-Viz Yellow
Deployment: Manual
Operation: Beacon will activate when wet with switch in the armed position; beacon
can also be activated manually. To deactivate, flip switch to "OFF" position
Waterproof: 10.0 m (33.0 ft)
Accessories: 9321Mounting bracket
Certification:Meets ETS 300 152 requirements; CE, FCC approved
Limited Warranty:1 year
Carton Dimensions: 12.7 x 24.8 x 19.5 cm (5.0 x 9.75 x 7.5 in)
Units Per Carton: 4
Carton Weight: 1.4 kg (3.0 lbs)
Frequency: 121.5 MHz
Battery Type: DL223A lithium or equivalent
Radiated Power: 100 mW nominal (ETS requirement is 75 mW)
Operational Life: 24 hours @ -10o
C (14o
F)
121.5 MHz Satellite Detectability Ends in 2009
ACR Electronics, Inc.
5757 Ravenswood Road
Fort Lauderdale, FL 33312, U.S.A.
Tel Worldwide: +1(954) 981-3333
Fax: +1(954) 983-5087
ACR and Artex Products - The Science of Survival | ACR ARTEX
Size: 12.7 x 7.4 x 4.1 cm (5.0 x 2.9 x 1.6 in
it was worth about $200, but virtually worthless now.
Bombay Explorer 44
The battery will almost certainly be past date and require replacement at vast cost as it is not 'supposed to be' user serviceable.
Also I think that I read something about 121.5 no longer being monitored, maybe someone with the facts can confirm this.
So worth zero and put it on EBAY.
121.5 mhz is a very short range signal, which is homed in on when a SAR already knows to be looking for you. Modern EPIRBs use a satellite link that relay your distress call (preferably with your GPS coordinates) to a shore facility. This ancient technology is not very useful.
1 - 12 of 12 Posts
