1 - 6 of 6 Posts
Hello,
The end of my whisker pole has come off. I am not sure what I should use to reattach it. Can I use epoxy? JB Weld? Bulldog? Screws? I'm lost. Any suggestions?
Thanks
If it's a slip/slide in fit, self tapping machine screws should work. #6 or #8 x 3/8" or 1/2" long, 1 on ea side should do it, 180 deg. apart.
Discussion Starter · #4 ·
Thanks MacGyverRI for your amazingly quick reply. This should do the trick. I appreciate your help.
I have pop rivets for the ends of my whisker and spin poles. Screws might work also, may be better or worst, either in the end would work.
marty
Discussion Starter · #6 ·
Whisker pole flare
Hmmm, The end of the aluminum whisker :confused:pole is somewhat flared where the end pulled out. Another boater here suggested cutting off the pole just before the flare. Any thoughts?
1 - 6 of 6 Posts
