1 - 13 of 13 Posts
I was over on s/v Itinerant, helping Joe with his WiFi setup, and decided to write what I did. Joe had bought a NanoStation2 based on my recommendation and was having some trouble with it.
The equipment I've been recommending for cruising sailboats are either the NanoStation2 or the Loco2 for monohulls and the Bullet 2HP for multihulls. All the hardware is designed and manufactured by Ubiquiti Systems, and are designed not to require any device drivers.
All three units use a wired ethernet port and a wireless WiFi 2.4 GHz spectrum radio to either create a WiFi-to-Ethernet bridge or an Ethernet-to-WiFi router. The standard configuration for cruisers is using it as a WiFi-to-Ethernet Bridge.
This approach has two major advantages over the solutions that use an external amplified antenna or a USB network adapter. First, there are no coaxial cable losses, since the electronics are located at the antenna. Second, there are far fewer stability and compatibility issues, since there are no device drivers to install.
The main reason I recommend the NS2/Loco2 for monohulls has to do with their stability and the greater vertical angle of coverage that the NS2 and Loco2 have, 20˚ and 60˚ respectively. I generally recommend these be hoisted on a halyard with a control line, so that you can aim the antenna, since they only cover about 60˚ horizontally. I've had fairly decent success using the NS2 to setup a terrestrial link of over two miles.
For the Bullet 2HP, I've been recommending a 10 dB gain omnidirectional antenna, which seems to be working fairly well for most of the boats it has been installed on. The 10 dB gain antenna has a pretty narrow angle of vertical coverage, and isn't really well suited for monohulls IMHO. Most of these have been permanently mounted.
In both cases, the higher the antenna is hoisted or mounted, the greater the range you will generally have. Be aware that you will often have less range in heavily developed areas, as there will generally be more noise sources and interference in the open 2.4 GHz frequency range, the NS2/Loco2/Bullet 2HP and 802.11 b/g/n equipment usually use.
Equipment required:
A NanoStation2, a Loco2 or a Bullet 2HP WiFi Bridge/Router with an antenna. The NS2/Loco2 have an antenna integrated into them.
A Power Over Ethernet power injector tap. This allows you to run a single wire for the data and power connections for the ethernet bridge.
A power cord for the POE injector to wire into the boat's electrical system or plug into a 12 VDC outlet. These units can use a fairly wide range of voltages, and will generally be fine with the 12VDC system on most boats. Typically, the units will work on voltages from about 9 VDC to about 24 VDC. Anything above 24 VDC may cause a problem.
A long ethernet cable, preferably exterior grade for the connection to the bridge unit. This will be connected to the data/power port on the POE injector.
A shorter ethernet cable for the connection inside the boat between the computer and the POE injector. This will be connected to the data port on the POE injector.
A computer to configure the bridge with.
What Now?
The configuration of the NS2/L2/B2HP, generically referred to as the UBNT bridge from now on, are all basically the same, and require basically the same steps, but the steps will vary depending on what OS you are running. I am writing instructions for Windows XP and Mac OS X. If you are running Vista, then you're on your own, since I don't own a Vista-based machine. However, the Windows XP instructions should work for most Vista users, if the software I recommend works in Vista as it says it does. If you are using a Linux-based machine, the instructions for Mac OS X will a pretty good starting point, but most Linux users are tech-savvy enough to figure it out themselves.
If you are new to WiFi networks, you may want to read the WiFi security primer I wrote, which will give you a fairly good overview of what the different terms you will run into in the rest of this article.
Using Windows for Configuration
Since the majority of you will be on some variant of MS Windows, I'll go over the Windows XP configuration first.
First, do yourself a favor and download Easy Net Switch, which is a shareware application that will greatly simplify this for you.
Setting up Easy Net Switch
After installing Easy Net Switch, you need to setup at least three profiles. One will be called "UBNT Configuration", another will be called "UBNT Internet" and the third will be called "Automatic".
The "UBNT Configuration" profile will have the WiFi card in your machine disabled. It will have the Ethernet card setup with the IP address "192.168.1.100". The subnet mask should be "255.255.255.0".
The "UBNT Internet" profile will have the WiFi card in your machine disabled. It will have the Ethernet card setup to get the IP address automatically.
The "Automatic" profile will have both the WiFi and Ethernet cards enabled. It will have both of them setup to get their IP addresses automatically.
Configuring the Bridge
Run Easy Net Switch and select the "UBNT Configuration" profile. This will put your computer on the same "logical" network as the UBNT bridge. Open up your web browser and enter "192.168.1.20" into the address bar and hit "Enter". A window should pop-up asking for the login credentials for your bridge. The default username and password is "ubnt". Enter the username and password and log into the bridge.
Selecting a Network
Click on the "Link Setup" tab, and click on the "Select" button. A pop-up window should appear with a list of WiFi networks visible to the UBNT bridge. This screen also gives you a fair amount of useful information, like the network SSIDs of the networks, the signal strength, what type of security they use and what channel they are on.
Now, click the button on to the left of the network you want to use. Then click on the "Select" button. The pop-up window should close and return you to the "Link Setup" screen.
Check that the "Wireless Mode" is set for "Station". I believe this is the default choice from the factory, but you should check to make sure the correct mode is selected.
Now, if the network SSID you selected had security turned on, you will need to enter the password or pre-shared key on this page. WEP is not a secure encryption scheme, but some people still use it. WPA or WPA2 are far more secure encryption schemes.
Now, click the "Change" button at the bottom of the screen. The screen should refresh and you'll need to click the "Accept" button that now appears near the top of the screen. A window will pop-up saying that the changes are being applied.
You should now be on the selected WiFi network, and if you click on the "Main" tab, you should see the signal strength indicator, a series of colored boxes near the top of the screen, active now.
Surfing the Internet
Now open the Easy Net Switch program and select the "UBNT Internet" profile. Once the ethernet card comes back up as connected, you should now be on the internet. However, some WiFi networks will require you to login, sign up or click a license agreement of some sort.
Using Mac OS X for Configuration
This article assumes you're using either Mac OS X 10.4 or 10.5, Tiger or Leopard, at a minimum.
Setting up Network Preferences:
Open "System Preferences" and then select the "Network" icon. You will need to setup at least three location profiles. One will be called "UBNT Configuration", another will be called "UBNT Internet" and the third will be called "Automatic".
The "UBNT Configuration" profile will have the Airport card in your machine disabled. It will have the Ethernet card setup with the IP address "192.168.1.100". The subnet mask should be "255.255.255.0".
The "UBNT Internet" profile will have the Airport card in your machine disabled. It will have the Ethernet card setup to get the IP address automatically, via DHCP.
The "Automatic" profile will have both the Airport and Ethernet cards enabled. It will have both of them setup to get their IP addresses automatically, via DHCP.
Select the "UBNT Configuration" profile from the "Location" sub-menu in the "Apple menu". This will put your computer on the same "logical" network as the UBNT bridge. Open up your web browser and enter "192.168.1.20" into the address bar and hit "enter". A window should pop-up asking for the login credentials for your bridge. The default username and password is "ubnt". Enter the username and password and log into the bridge.
Selecting a Network
Select the "UBNT Internet" profile from the "Location" sub-menu in the "Apple menu". Once the ethernet card comes back up as connected, you should now be on the internet. However, some WiFi networks will require you to login, sign up or click a license agreement of some sort.
Mounting the UBNT Bridge
I generally recommend the NS2 and Loco2 units be hoisted aloft on a halyard. You should provide some strain relief for the ethernet cable, so the weight of the cable isn't being supported solely by the ethernet jack. The NS2 or Loco2 should also have a "tail", which is an extra line that will allow you to "aim" the unit. The higher it is hoisted, the further the range of the unit will be.
The Bullet 2HP units as equipped with the 10 dB gain omindirectional antenna should generally be mounted as a fixed mount device. Again, these units could be hoisted on a halyard, but you'd want some strain relief to prevent the weight of the cable from being supported by the Bullet unit itself.
Some Recommended First Time Changes:
I would highly recommend you change the password the first time you log into the bridge. I would also highly recommend that you change the router's name. Changing the IP address for the UBNT bridge may also be a good idea, but that would require you to modify the directions above accordingly. These are basic security precautions and will help prevent unauthorized changes to you UBNT bridge's setup.
Some Computing Advice for Cruisers
If you're using WiFi to check e-mail, I would highly recommend using SSL or TLS-based encryption for your e-mail. If you don't do this, your e-mail username, password and e-mail will be visible to anyone on the same WiFi network as you. Most modern e-mail servers support this feature, and most e-mail programs support this feature.
Using a good e-mail program can be useful, since it will allow you to download your e-mail and then read and reply to your e-mail while off-line, and then connect to send your replies over a fairly short time period. This can save you money if you use a satellite phone for internet access.
I would also recommend you use the "secure" versions of any websites you have to log into. The secure versions of a website use the "https://" version of the website's url, but not all websites support this.
"WEP is not a secure encryption scheme, but some people still use it. WPA or WPA2 are far more secure encryption schemes."
FWIW, there have been some recent cracks against plain-vanilla WPA, folks should no longer consider it secure unless a strong password is used. (i.e. long, mixed characters.)
Discussion Starter · #5 ·
True, but the WPA and WPA2 algorithms are still fairly secure, and far more so than WEP ever was. :) The WPA PSK I generally use on my networks is at least 24 bytes in length and uses mixed upper and lower alpha, numeric and symbols... so, I doubt it is vulnerable to cracking anytime soon. :)
Discussion Starter · #6 · (Edited)
Jaak-
As I said in my OP, the longest distance connection I've gotten with the NS2 hardware, using one on each end, is OVER TWO MILES. The design specification, which is a bit conservative IMHO, is 15 km.
I'd point out that if you need to hoist the USB based solution you're using up the mast more than about 16', you'll need to purchase an amplified USB signal boosting cable... where the NS2, Loco2 or Bullet 2HP can all be used at the top of a very tall mast without any such need for additional equipment or introducing breaks in the cable which would be vulnerable to moisture intrusion.
Also, the USB network device drivers tend to be the least stable of all the network device drivers. By not having to install any device drivers, I avoid any driver instability and hardware/OS incompatibility issues.
The NS2 and Loco2 have a 60˚ angle of coverage. If you're not able to get the antenna oriented successfully with that much coverage, you're doing something wrong. I wouldn't exactly call 60˚ precision alignment. I'd also point out that the WiFire probably has a narrower angle of coverage than the NS2 or Loco2. The Bullet 2HP's coverage is really antenna delimited, and depends on what antenna you have selected for it.
BTW, using the 18 dB gain parabolic grid antennae with a 2.5˚ angle of coverage would require "precision alignment", and I've used them to setup multiple 6+ mile links out in Utah. Alignment was done using GPS and laser pointers to get them roughly aligned and using signal metering software to optimize the alignment. Of course, the fact that much of this was done in basically unpopulated areas had a lot to do with the success over that distance, since there were far fewer noise sources or competing electronics on the spectrum in question than would have been the case in someplace more populated or urban.
Super-interesting product. I've been using USB interfaced solution from Wi-Fire What is the longest distance, You achieved to connect?
I see, that Nanostation 2 antenna has quite narrow polar diagram, requires exact aligning to the WiFi base station. How did You solve that?
Jaak
Hello sailingdog,
Good info - thanks. I'm trying to select a solution for an upcoming cruise this winter - on a 28' sailboat along the east-coast & bahamas where i will almost always anchor (and swing some) rather than dock (and not swing). So the 60 deg azimuth beam width has me a little concerned.
The question I have is this: with the ns2, you get 60 deg beam and 10 dBi gain. Wouldn't a bullet2hp with a 8 dBi omni be a better choice? That way, I get almost equivalent gain, but with 360 deg coverage. My boat can wag at anchor and even do 180 deg shift with the tide and i won't be constantly realigning the antenna.
with a bullet, I can also easily swap the antenna for something directional if/when i need it...
what do you think?
Seinor Member
Ahoy Dog
Good write up, you could of mentioned typing (ANY) in the ESSID box .
This would allow the NS2 to lock on the strongest, unprotected, signal recieved.
We use NS5's and 2's here at the marina for its wifi system very reliable. With the old system I would have to reset all the AP's at least once every other week. The suckers were not as cheap as the NS's.
Fair Winds
Dave
Discussion Starter · #9 ·
The problem is that the 8 dB gain omni is likely to have a relatively narrow vertical angle of coverage. If your boat rolls much, it is likely to trash the signal every time the boat rocks and rolls. Most boats don't swing all that much in a good anchorage. :)
Hello sailingdog,
what do you think?
Discussion Starter · #10 ·
Yes, that's true...
Fair Winds
Dave
8 dBi omnis have ~15 deg elevation beam - so so long as i don't heal more than 7 degs while at anchor, i'm ok ;-).
For comparison, the ns2's elevation beam is 30 deg.
I'm still torn between the choices... so many folks seem to have proven performance using 8 dBi omnis... cost wise, the ns2 is a clear winner - $75 for the whole package... whereas the bullet2hp+omni+poe would easily run me $120+.
"I'm still torn between the choices... "
Try the 8db omni, and instead of lashing it to a whip, SUSPEND it from something. Suspend it with a foot or two or parachute cord (something like and flexible) so that the boat rocks under it, allowing the antenna to remain more vertical as the boat heels.
IIRC you should be able to suspend it rightside-up or upside-down, either way, without the signal being affected.
I have a nanostation 2 and so far have never anchored or docked in the chesapeake without finding a free wifi signal. I was all prepared to hoist it but so far it has worked just putting it on the cabin top under the dodger or on top of the bimini. I need to aim it correctly but it works great
1 - 13 of 13 Posts
