1 - 10 of 10 Posts
Just wondering if this actually works?
i saw a large boat ( 35+ ) with windmills and asked and they said to keep the batteries at full charge.
Is that possible?
Does anyone on here have one or info?
They are called wind generators. Yes, they work. Most require about 15kts wind to get anything appreciable. At best you might be looking at 6-8 a/h. Over 24 hours, that might be someintg good, but how often does the wind blow 15+ for 24 hours??? Depenging on your location, solar may be a better choice. It certainly was for me. Many cruisers use the two in combination. I say just put up a large solar array and be done with it.
- CD
john that was funny but you might want to say it was a joke, some newbs might think its real
Excuse me, but are you saying that the SailFan(TM) is a joke!! :hothead :hothead Did you not read to the very end of the thread where I posted the letter from a very satisfied Sir Byron Plympton, Order of B.S., who had made a successful transatlantic voyage aboard S/V Windless using SailFan(TM) ?? If you are having trouble finding it, I believe that post was dated April 1, 2009.
P.S. I thought the winkies (";) ;) ") I had added above would do the trick.:D :D :D :D
SPCalan1,
Just want to make sure you know that my earlier posts were in jest -- we have to amuse ourselves at times.:D
CD's answer is the one you want. But I will add to it by saying that in the tropical trade wind regions, a wind generator can be a fairly effective battery charger. True, the wind doesn't always blow favorably even in the trades, but then again in the tropics it's dark for 12 hours a day, which isn't the best environment for solar panels, either.
In any case, you probably don't need solar or wind charging for basic weekending sailing.
10 or 15 years ago a bloke from Australia took a 35'cruising sailboat ,installed a short stocky mast and put a large 2 bladed prop on the mast(about 20' dia.)He connected it with a driveshaft to a transmission and a prop under water.
The boat would go directly to windward,something all sailors would appreciate!It must have had drawbacks as that was the last I saw of it.I think it was in cruising world.
Phil
Bombay Explorer 44
Loads of threads on this topic around in the cruising forums. Waste of time in most inland lake locations I would think but anchor out where the trades blow down island with a Kiss and 100 amphours plus is normal. [ 4-5 amps x 24 hours]
1 - 10 of 10 Posts
