Hi all,
I am in the process of winterizing my 21-ft trailer sailboat that is stored on land near the ocean in a Pacific NW environment for the winter (Vancouver, BC) - high humidity.
I just installed a new Vetus 55L flexible water tank in the boat this year and do not want it to get fouled with algae, etc. Because of the set up, its not possible to remove it from the boat. My plan is to pump out all the existing water.
My worry with just leaving it drained is that there could be some pools of water or ingressing moisture that could mold/grow algae inside the tank/lines.
I was thinking of using the "sterilization" procedure in the manual, filling the whole tank and lines with 5:1 water:white vinegar mixture and then leaving it all winter. Would this be a suitable strategy to combat any algae/mold growth? Or should I just leave it as fully drained as possible?
Any input is appreciated! Thanks.
