Winterizing new 4HP Mercury
70 views 5 replies 6 participants last post by  OntarioTheLake
#1 ·
I have a new 4HP Mercury outboard. I want to flush the cooling with fresh water. I see the packet came with the adapter to screw into the motor but.. Has anyone figured out how to use it? It is really small for adding a plastic tube big enough to move water through it. Any other suggestions of what I can use?
#2 ·
I have a 32 gallon (I think - It might be the 44 gallon one though) Brute trash barrel. I fill it part way with fresh water from the hose (probably 8 gallons or so) and then hang my outboard motor so that the intake is below the water line. I start the motor, and put it in gear. After I run it for a few minutes, I fog the carburetor, pull the plug and fog the cylinder. Then, I replace the sparkplug but do not reconnect the sparkplug wire. I then drain the carb. I do all of this while the motor is hung on the barrel. If I had a four stroke I would then drain the engine oil while the outboard was on the barrel too. I then take the motor off of the barrel and change the lower unit oil. I hang the outboard on piece of wood in a vice in my garage for the lower unit oil change. Finally, before I put everything away, I dump the water out of the barrel.
#4 ·
For a small outboard that can be easily lifted, I’d do it exactly as described by E. If you can’t, you can purchase a device that grips around the outside of the lower leg, over the water intake. They look like rubber ear muffs. You connect a hose to it and it provides cooling/lubricating/flushing water, plus it permits you to warm the oil, out of the water, to change it.
If you‘re not storing the outboard in a heated place, I’d run some antifreeze through that same device. Outboards are technically supposed to drain, but I have to think some water gets trapped.
#5 ·
HI,
Step one is to make or buy an engine stand. I made one out of some scrap 2 X 4. I see there are cheap ones for sale on Amazon. One the outboard is mounted on the stand I basically follow the instructions listed above. I don't drain the carb, instead I add fuel stabilizer to some fuel, I run the engine for a few minutes, then I turn off the fuel flow and run the carb dry.
Good luck,
Barry
#6 ·
In the cold of the Great Lakes I don’t worry about flushing salt water.
At the end of the season I start the motor, pull the fuel line, and run the carb as dry as possible. Then put it on a motor stand for six months.
This is what I’ve done with the Merc 15 for 20 years, and the Johnson 9.5 for the prior 25 years.
