- Reaction score
- 4
I know this is a newbie question but are there wirelss depth finders that are any good and reasonably priced? I would love to not have to worry about running that wire.
Thanks
Joe
Thanks
Joe
so if i ever need to pop it loose i can, then i could use a new thin layer to put a new one in the same spot ( assuming same trans ). then i would not have 2, 3, or 4 globs of gel coat under the settee from each new one.Why did you wax it?
Brian
I've been told the same thing about silicone under the transducer, I didn't do that.Epoxy is the best way to attach a transducer to the hull. Sealants such as silicone will have an impact on depth sounder performance. Humminbird agrees.
Brian
