My bilge pump stopped working and because of a left open intake valve for the head the bilge got filled. The bilge was a mucky mess. I found both wires were broken. This is a group owned boat and some of the maintenance leave the boat in less than Bristol condition. Even the wire stripper on the boat would not strip the wires adequately.
It looks like the previous connections were made with some type of crimp. I used some wire nuts to get the bilge going and then left the wires hanging outside the bilge for a temporary fix. I am going back on Saturday to do it correctly.
My plan is to solder the wires, then put heat shrink tubing over the joints, then secure the joint above the bilge water level. My other plan is to do it the other way if you guys tell me there is a better method.
One other question is how to reduce the water level in the bilge? This boat is an Ericson 32. The bilge pump and float switch are on a piece of wood together and raise it up a bit. Would it be better to mount them right onto the bottom of the bilge? How do I do that?
