1 - 1 of 1 Posts
Im trying to install a new Xantrex 1800 Xm w/auto transfer. Xantrex manual says all incoming ac goes thru Inverter where its protected by a 15 amp GFI. This is kind of insane as I have a 30amp shore line and a Air Conditioner that draws 28amps start-up. I have a generator also and a rotary switch on elect panel that distributes the AC -----------ie "shore power-generator-inverter" If I connect the Invert like the old one to the Inverter post on the rotary switch and a common neutral bus it does not work! HELP! (thanks) PS previous boat had a non-auto transfer Xantrex ---it worked perfectly for years. Can I bypass the auto transfer somehow???Help:laugher
1 - 1 of 1 Posts
