1 - 2 of 2 Posts
The PO of my current boat put sunbrella window covers on the inside of the window sills on my Catalina 27. I began removing them this weekend and have realised where my last couple of water leaks originate. When I removed the plastic sill it exposes the plywood of the hull. It appears that some of the wood has chipped away and some has warped over time. I am planning to go out this week to remove the windows and re-caulk for a better seal, but my question is about the wood- is there a wood filler or an epoxy anyone can recommend I use to fill the gaps in the wood and also a white paint to paint over the filler when it is dry? I would like this to look as good as possible but also to prevent the current leaks from coming back.
Any recommendations?
Thanks,
Chris
Dig out all of the rotten wood all around the frame. Make sure you don't have a bigger problem with rot than just around the ports. Fill with epoxy...if a large area use microbaloons mixed in. Re-drill and re-caulk.
1 - 2 of 2 Posts
