1 - 13 of 13 Posts
Any thoughts on if this marine grade ply is refinishable? Or a complete replace ?
139855
ASA and PSIA Instructor
I dont think you can refinish it, however you might be able to peel off the teak veneer and just replace that.
Master Mariner
I've had great luck stripping off the varnish on the bad areas, sanding it lightly, then using a wood stain to get it back to the proper color. Then revarnish.
As Steve Bateman said... Find the leak. Remove the port and rebed it, or fix the gasket, or whatever it needs.
As Capta said... "I've had great luck stripping off the varnish on the bad areas, sanding it lightly, then using a wood stain to get it back to the proper color. Then revarnish." Just be really careful with the sanding. The teak veneer is thin, really thin. And, you may need to bleach the teak with Clorox or oxalic acid to remove any black mildew.
I agree that step one is to be certain that any leaking has been remedied.
And, I'm with pdqaltair on this...consider painting it. I see no reason why we have to be slaves to the aesthetic of varnished veneers. A lot of classic wooden yachts had mostly painted interiors with some varnished trim.
Or paint it.
This. Remove ports. Strip. Sand. Fill. Paint. Saturating epoxies and epoxy paints are made for this kind of work.
Discussion Starter · #12 ·
No not yet
Thanks much for thoughts. Ive just never seen anything like it/bubbling varnish
I've seen bubbling from heat, from strippers (solvents), and from failure of an upper coat to adhere properly to the coat below.
1 - 13 of 13 Posts
