1 - 17 of 17 Posts
Singlehander by Default
Discussion Starter #1
I have two of these on each side of my laguna 22, one at 6 foot from the bow and another at 12 foot on each side. Wondering what the hell they are used for--to the point of nagging at me. Thinking they may be some kind of guides for the storm(or #1 jib) sheets when in use, or maybe lifeline attachments, although there are none on the stern area of the boat.
They look like fairleads for a furling line, although that would generally only be on one side. Has the boat ever had a furling jib?
Reactions: Crackaloon
Yup, looks like leads for the furling line, on my C22 they run down the starboard side.
They could be handy, like if you wanted to put a downhaul on one of your sails...
Discussion Starter #5
Thanks for the replies so far. The furling line had entered my mind, but they run down both sides of the boat. I was thinking tie-downs as well, but kind of a small boat to be tying things down up there. Really limits space on an already small bow area. Thinking about using them to stow a small inflatable while underway tho.
Senior Moment Member
Cheapo substitutes for sheet blocks?
Discussion Starter #7
That was kinda my first thought.
Are there cleats aft of the leads? If the boat was once rigged for a spinnaker they could be leads for a double ended foreguy.
Discussion Starter #10
No cleats in the area until you get back to the cockpit.
@ BL-- You typed that very authoritatively, are you stating or guessing? I can't tell.
Guys - it's a Windrose 22 - think cheapest possible solution to a minimum sailing configuration.
I doubt there has EVER been one with a spinnaker barber hauler setup. :)
Econo small boats frequently have bulldog fairleads for sheet leads where a more substantial boat would have track & blocks.
My first 20' was set up exactly that way.
Sailor
I think they are for double line furling control lines. You would have a continuous loop necessitating 2 lines being fed back to the cockpit. I might have the name wrong but not the function.
Tod
I have close to the same set up on my 26 ft "cheap" sailboat. I use the forward ones when I have my storm jib up and the aft ones when my genoa is being used. They seem to have been placed in the best spot possible for use with the 2 sails and seem to work very well. Keep in mind I'm not racing and have nothing to prove. Just like to get out on the water and sail. Bigger and more precise boats have a track so the point can be adjusted depending on what sail is being used.
1 - 17 of 17 Posts
