Mark..
Beneteau electric 12v should be no different from any other boat.
I have over time including one major re wire redone all the OEM stuff:
new alternator - high output - new adjuster bracket heavier
new smart external regulator Balmar 614 now
added electric monitor... now Link20
added solar w/ regulator
changed to 8D AGMs with new plywood batt box
new wiring and cables for 12v mains
new fuses 100amp
new battery switch
I have produced a series of wiring diagrams... I attached one previously
This IS a lot of work and expense.
Start with the right batt switch, upgrade wiring and batts if need be. Add the echo charge.
A high output alternator works for me because I don't use shore power or wind or a gen set or a lot of solar and my refer is engine drive so I am running it anyway... might as well make a lot of amps.
Do you have a circuit diagram for your boat? If so start there. If not.. make one.
Mine looks almost identical to yours except I have 6-6volt AGM
Great idea making a diagram as a living document of not only the battery charging connections but also of you panel
When I did my complete rewire it was way wY easier to do it from jump, and using it to trace flows made it easier to
Wiork on the project. Now if there's a glitch or issue it's easy to use the diagram to think and point
Agree with Mark too....simple for this stuff is better
After reading lots of Maine's threads and how to stuff it is important to match batteries, charging capacities , temp
Monitors with alternator charging . Along with an external regulator. You can waste a lot of needless money if
You don't match this stuff. You can fix for a couple years or have a long term plan
Also important here is proper care of your batteries, ie equalizing, desulfating and how to "train" them to carry the fullest charge so you don't program a Battery unwittingly to only max at 85% because you don't charge it fully time after time. To me this is the most neglected part of my friends electrical systems. Many of them moan or comp,ain't that they go through batteries every few years. They have generators, solar, and wind re charging and alternators, as well as shore power. In almost every case they have just ignored or never took the time to understand the concepts here. Yes I argue with them, you can spend more money, time and sweat replacing batteries, or maybe just understand what they have to do to prevent them from happening.
It's not rocket science....but it is science. We are lucky as Maine has given I fo and primers on making it easier for us.
