1 - 1 of 1 Posts
Discussion Starter #1 (Edited by Moderator)
Xantrex Truecharge 40+ amp Battery Charger
Owner required larger charger. Charger has not been used.
Truecharge 40 multistage battery chargers are microprocessor controlled, 40 amp output, charges up to three battery banks simultaneously, independent settings for AGM, flooded or gel lead-acid batteries.
Charge mode selection switch allows selection of 3-step (bulk/absorption/float) or 2-step (bulk/absorption/off) depending on battery
manufacturer recommendation. Select 13.5 volt fixed to use as a pure DC power supply.
Wide voltage range operation (90-135 VAC, 50/60 Hz) with operating temp. 0° to 40° C . Model designed for deep-cycle marine, RV, and industrial batteries.
Weight 7.5 lbs Length 15" Width 6.5" Height 2.75"
Charger available in Key Largo, Florida.
Please call 360.356-4504 9 am - 5 pm EST
Asking Price: $250.00
Condition: Excellent
1 - 1 of 1 Posts
