21 - 40 of 42 Posts
Southern Cross 35
. It is a common fail point when a hole will develop and allow oil to drop directly into the exhaust manifold passage of the head, bypassing the cylinder, which would explain why you don't have significant smoke.
This is interesting, I'd not heard of this issue before. Is the fix for this a new/used head? Or can the head be repaired if this were to happen? Is there any way to diagnose this short of pulling the head and taking it to a machine shop?
If the failure is in that passage, no machine shop will even bother to attempt to repair it because the cause of the failure renders the surrounding material too poor to weld to and the cost of attempting puts you in the replacement head range. Replacement is the simplest and most reasonable step, provided this is the fail point. remember, not being able to see the engine means I really don't know what your problem is. I'm just giving you things to look at and to think about when you are "getting into it". I've seen people attempt to use liquid steel to patch the holes but always to just sell the boat and rid themselves if the problem. The patches don't last, obviously.
Discussion Starter · #23 ·
Oh that's a good lead. I'll pull the valve cover first then. Splashing back on the 14th, and will be checking the engine that same week. The mechanic I'm speaking to may have a spare head for me.
Cheers, will report back.
Discussion Starter · #24 ·
I pulled the head off today, and my mechanic friend was right. I have a hole in the head, visible through the hole where the exhaust elbow and the head meet. I did not have to remove the head to see this, but it had to be done anyway... could not see a hole while the head was mounted.
139625
My engine was fine before I serviced the elbow, but that was only because layers of carbon were keeping the hole shut. I cleaned them off... and immediately after I started to have oil mixed in with the water. So yea, I've found my problem.
Glad you at least figured it out, if not glad to hear how significant it is. What’s the next move? New head? Is the engine worth rebuilding? Why do you think this occurred and could there be other failures looming?
North Star 26
I pulled the head off today, and my mechanic friend was right. I have a hole in the head, visible through the hole where the exhaust elbow and the head meet. I did not have to remove the head to see this, but it had to be done anyway... could not see a hole while the head was mounted. View attachment 139625
Oofda! Well, they're good engines if you can find a new head....
Discussion Starter · #27 ·
Glad you at least figured it out, if not glad to hear how significant it is. What's the next move? New head? Is the engine worth rebuilding? Why do you think this occurred and could there be other failures looming?
It's a bittersweet discovery yes. In all, am glad I've found the issue.
I may have found a replacement head, a mechanic I know was re-building a Yanmar and may be willing to part with the head. Anyway, last time we met up he made the suggestion.
Some of my more hardcore DIY friends suggested getting bronze brazing rods, heating the whole thing up 500 degrees in a bbq and brazing the area (!!!). More reasonably, he mentioned pinning the hole, but I am not sure if that's really a good idea either ;).
North Star 26
I'm all about heroic DIY saves, but patching that is another hidden problem waiting to happen. You'll never be able to monitor the fix but at least you won't have to guess when it fails. New head saves you time and worry.
There is a guy in Oak Bay selling a 2GM with a busted crank. You might be able to get the whole thing for 1/3rd the cost of a new head, and a back up gear. If it were on the mainland, I'd go buy it just for the gear and head.
Discussion Starter · #31 ·
For now, I've got two options: mechanic friend has a used head, and a 2GM20 that is currently being re-built that I can swap to. I am considering doing a swap, since the alternate has fresh water cooling. Price isn't bad either, would be able to swap parts from my current engine too.
I would not jerry-rig a repair, unless I considered the engine disposable. In High School, that's exactly how I viewed some things, as the right repairs cost more than the car. The cost of the jerry-rigged repair was just rent for a year. Of course, I'll I needed to do was coast to the side of the road, when I lost that bet. Aboard, I find Murphy asks me to pay up at the worst time.
In this case, I'd sure like to get my head around why such catastropic damage and whether that cause was likely to have impacted other major components as well.
This sounds very familiar. I have a 3YM30 on my sailboat and what is going on here is the same same. I have a blueish smoke and lube oil spitting out my exhaust. I had my oil level rise on my dip-stick {thinking fuel oil was getting in the oil pan} I had the Fuel Injection pump and injectors overhauled. After replacing the fuel injection pump and the adding a new lift pump and injectors.... same issues. All the while the engine has started right up. No alarms. I have had to replace the impellers in my raw water pump a few times after running this boat into the mud. I'm thinking overhauling the head is the next step.
21 - 40 of 42 Posts
