Hi Sailnet,
I've recently acquired a 30 year old Yanmar 3GMD which runs at 67C (152.6F) at the crankcase when revved to 1800rpm after a few minutes. This is a little hot for my liking as I'd like to try and get it to 2000rpm if possible - beating into 25knt wind in a very narrow and shallow channel will be impossible otherwise.
When I replaced all the zincs recently (there are 3) I noticed a massive amount of white scale which I'm assuming is zinc oxide inside the engine block, so I'm wanting to descale. I bought Rydlyme as after some research it seems the most gentle.
My concern is some of this white zinc oxide is visible on the outside of the engine. Does this mean there is a small leak in the raw water system which if descaled will turn the engine into a leaky bucket?
If there are leaks, is it possible to seal, say if part there's a crack or corrosion in the engine block itself?
Thanks a lot for your help,
Brandon
Brandon
