1 - 10 of 10 Posts
I recently replaced the saltwater hose connecting the rawwater pump with the heatechanger.
Now there is a slight leak of saltwater from the connection between hose and the heat exchanger.
I have tightened the hose clamp as much as I dared to.
Any tips or tricks on how to fix this is welcome
Hey,
I'm not trying to be a jerk, but have you:
Made sure the fittings are clean and free of corrosion?
Made sure the hose is completely on the fitting, all the way on?
That the hose clamp(s) are over the barb, bump, whatever, and are tight?
And lastly, that the hose is the correct diameter?
If all those things are done I can't see how there can be a drip.
Good luck,
Barry
1 - 10 of 10 Posts
