1 - 7 of 7 Posts
Discussion Starter #1 (Edited)
This is the boat.
]http://www.yachtworld.com/boats/1979/Morgan-321---Recent-Survey-[/font]
2054206/Westbrook/CT/United-States.
It has been cared for with many upgrades and well maintained and replaced parts. We did notice that if you work the the bow pulpit back and forth water squirts out of the plate fastened to the deck. So there must be water intrusion in the deck. Walking carefully around the deck I could detect no sponginess.
I told the potential buyer three things:
1. A large percentage of people would not consider this boat at any prices as the cost of a deck job is higher than the cost of the boat.[/font]
2. Some people would use the deck problem to get a cheap price and figure that it will still sail with a soft deck for many years. The boat is asking 20k offer 12k sail for 5 years and whatever you sell it for you sell it for. You will probably get more that 0 for it and it is a cheap way to get a roomy boat.[/font]
3. If you remove the pulpit and drill a 1" hole under each stanchion and dig out core and pot and re-bed pulpit the problem will not be fixed but at least arrested.[/font]
4. If it is let go long enough the deck will compress the sides will flex and rig will fall down. I think the boat has years to go before a safety situation like that is likely. The deck has been painted and the surface has thousands of hairline cracks. This will continue and the deck will continue to look worse and worse until it has to be repainted but the new paint will only last a couple of seasons before it cracks too.
Do you think I gave it to him straight?
Handsome devil
As an Arrow.......................I think you have convinced them to continue on with their search....I hope you don't work on commission..:D
Just Kidding!!..
OH....btw....your link say page no longer available.
Discussion Starter #4 (Edited)
I think he means this one. Looks nice in the listing.
1979 Morgan 321 RECENT SURVEY Sail Boat For Sale -
Yep that's it.
Here is my preliminary findings I am sending to my new guy:
Morgan 321, 1978
<O:p</O:p
Overall look
The owner took obvious pride in this boat. His documentation is though. The bilge is bone dry dusty.
Sails are in good shape, lots of new plumbing.
Significant rust on the engine but it looks like it was cared for. New fuel filter, no obvious leaks.
It comes with recent canvas with adequate depth, speed and auto helm.
<O:p
In short for a 30 year old boat it shows very well
<O:p
Problem Areas
1. Stem head fitting appears to be missing some trim.
2. There is no bow roller.
3. Bow pulpit connections to deck show water seepage indicating water in deck
4. Port stanchion in deck shows water seepage indicating water in deck.
5. Deck and topsides was painted but stills shows extensive crazing and some damage to nonskid
6. Traveler on cabin top is only a single purchase. It is probably not usable.
7. Winches are not self tailing
8. Starboard chain plate bolt shows start of rust implying deck core wetness or deck leak even though deck hardware shows recent rebedding.
9. Forepeak cushions are worn out
10. Two fixed port lights are crazed
11. Engine is a raw water cooled style that requires more maintenance and expense
12. Bilge pump is loose bracket is disconnected.
13. Sump pump in shower is old and installed improperly (wire nuts)
14. Raw diesel smell by diesel tank, recommend replacing tank.
15. Running rigging will require replacement soon.
16. Only lunch hook anchor visible, no adequate ground tackle.
17. Inadequate ventilation for CNG tank
<O:p
Items not understood or not found.
1. Keel bolts are not accessible (could not find out how the keel was attached and if keel bolts exist. It may be an encapsulated keel)
2. The dodger zippers imply connecting canvas from dodger to bimini that was not seen on the boat.
3. Some safety check items found like life jackets but not all.
This is not an official survey but a simple half hour walk through. If you are serious about this boat we need to dig deeper.
Discussion Starter #5 (Edited)
As an Arrow.......................I think you have convinced them to continue on with their search.....
I'm not sure about that. He really likes the boat so I'm not even sure I should really push him to pass.
This is his first boat. He wants a big boat, he is a big guy and had no interest in the Catalina 25 type boats I showed him. In fact he now wants to look at some 34's. Problem is he dosen't want to commit big bucks for a newer boat, he never sailed before so I don't blame him.
So worse case scenario. He buys the boat for $15,000 sails one season and sells for what $10,000. I'm pretty sure the boat would sell in a couple days at 10g. So he looses 5g. He used to race stock cars so I doubt a couple thou one way or the other really matters. If he buys a really nice boat for 40,000 he may still have to sell at 35 and it may take a few months and rack up 5g in yard bills. So a cheaper boat with a marginal core may be less of a risk than a better more expensive boat.
Do you agree.?
Discussion Starter #6 (Edited)
Like I mentioned before my new friend knows absolutely nothing about boats. He seems like a really nice guy and I'm trying to help him out. After we saw the boat but before I went back and found the wet deck problem I sent him the following email. I called him today and asked if I scared him away and he said it was a little more expensive than he thought but he was still on board. I'm not a yacht broker even though I got to play one yesterday so I trying to be as truthfull as possible and not unnecessarily scare him off.
How accurate do you think I have been?
Here is the email:
Morgan 32<O:p</O:p
This is a link to the Morgan 321: http://www.yachtworld.com/boats/1979/Morgan-321---Recent-Survey-2054206/Westbrook/CT/United-States. The shoal draft will make it easy to get into any marina. It will not point as well as deeper draft boats but even so it has the same race handicap as the Catalina 30 which frankly is surprising as the C30 has a reputation of being reasonably fast.
I don’t know what kind of buyer you are. It may seem a little impulsive to buy effectively the first boat you saw but then on the other hand I’ve seen dozens of boats the last few months and it is one impressive boat. If it passes a closer inspection and survey it would be an amazing first boat. I am completely neutral on this subject and if you want to look at some more boats, maybe a little bigger even, that is good too. You will be hard pressed to find one in such good condition however. This Morgan is not hard-core blue water boat but it appears to be better made than most and people have done some ocean sailing with it. I’ve read of trips to Hawaii so it is a well respected solid design.
Value<O:p></O:p>
If you search on www.yachworld.com for sister ships you will see the price from 44g on down. The one we looked at was the least expensive in the country. I don’t know the sellers situation and how flexible the price is but it seems to be priced well.
Purchasing Process<O:p></O:p>
The standard yacht purchase contract has language that makes the purchase subject to survey and sea trial. The way it works is you sign a purchase agreement and write a check for 10%. Then you do a quick haul I’m guessing about $600. You get a survey about $600. Do a sea trial and either accept or reject the boat. You are on the hook for the 1,000 for survey and haul but if you reject the boat for any reason you get back the deposit. If the survey identifies any problems the seller can reduce the price to compensate or offer to fix. I would recommend reducing the price and doing the work yourself. You get a better job that way. All that’s left is to get the insurance binder, pay the registration to the state $150.00 and of course sales tax. The boat has a recent survey which Gene will give me. Gene will try to convince you to not do a survey, saving 1,000, and go by the sellers survey. For obvious reasons that is a lot more risky. The winter storage may already have been paid and that is worth $1,400, we should ask.
<O:p
Issues
<O:p· The CNG installation should be vented. I’ll check on that tomorrow.
· The 2QM20h engine is a raw water cooled engine which if carefully maintained may be ok but it might be worth having someone check it since it is old. It may have a fresh water retrofit. I’ll check tomorrow.
· Raw water cooled engines don’t put out as much hot water so that’s another thing I will look into.
The following prices are rough estimates using the big yard we were in as a guide. Some prices may be less but boats are in no way cheap and I am certain to miss some items from the list. You want to be able to afford what you buy so you will enjoy it. This is a little unfair in one sense because no one I know just starting out in boating gets to see all these numbers before they get started. Usually they are hooked before they figure out the real tab. So if these numbers ruin it for you I’m sorry, but you asked so here they are.
<O:p
Acquisition Costs<O:p></O:p>
<TABLE style="BORDER-BOTTOM: medium none; BORDER-LEFT: medium none; MARGIN: auto auto auto 0.25in; BORDER-COLLAPSE: collapse; BORDER-TOP: medium none; BORDER-RIGHT: medium none; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoTableGrid border=1 cellSpacing=0 cellPadding=0><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1" vAlign=top width=283>Item <O:p></O:p>
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1" vAlign=top width=78>Cost<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Boat
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>20,000
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Taxes
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>1,200
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Survey
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>600
</TD></TR><TR style="mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Hauling
</TD></TR><TR style="mso-yfti-irow: 5"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>State License
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>150
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Winter Storage (may be paid)
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>1,400
</TD></TR><TR style="mso-yfti-irow: 7"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Insurance
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>700
</TD></TR><TR style="mso-yfti-irow: 8; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Total
</TD></TR></TBODY></TABLE>
<O:p
Yearly Costs<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Summer Slip
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>4,000
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Winter Storage
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Insurance
</TD></TR><TR style="mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Tow Boat
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Insurance
</TD></TR><TR style="mso-yfti-irow: 7"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Maintenance and upgrade budget
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>3,000
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>[
<O:p
Sample Project Costs<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Mainsail
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>1,800
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Genoa
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>New dodger, Bimini, connector, side curtains all around in plastic and screening. (Yes this stuff is expensive)
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>7,000
</TD></TR><TR style="mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Pull Mast
</TD></TR><TR style="mso-yfti-irow: 5"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Dinghy
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>1,600
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Dinghy Motor
</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 58.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-left-alt: solid black .5pt; mso-border-left-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1; mso-border-bottom-themecolor: text1; mso-border-right-themecolor: text1" vAlign=top width=78>1,000
</TD></TR><TR style="mso-yfti-irow: 7"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Roller Furling
</TD></TR><TR style="mso-yfti-irow: 8"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Mainsail cover
</TD></TR><TR style="mso-yfti-irow: 9"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Cockpit Cushions
</TD></TR><TR style="mso-yfti-irow: 10; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 2.95in; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid black .5pt; mso-border-themecolor: text1; mso-border-top-alt: solid black .5pt; mso-border-top-themecolor: text1" vAlign=top width=283>Shrink wrap
Handsome devil
I'm the wrong guy to ask...as I am confidant in my own repair abilities so am not miffed by some things other folks turn their noses up or freak out at and i can see past dirt.
It is a good time to buy up however so no reason to settle for..IMO..but that as we all know is just the beginning of the relation ship....best to start out on the cheap if unsure.
However there is a lot to be said for turn key boat buying ( yes i know there is no such thing but you know what i mean) read my signiture line
1 - 7 of 7 Posts
